motor knocking
Old April 20th, 2009, 08:04 PM   #1
87gtmustang's Avatar
1987 mustang GT
87gtmustang is on a distinguished road
Send a message via MSN to 87gtmustang
motor knocking
my motor is knocking. it seems to be coming from the middle. what can be the cause and is it worth fixing.
my ideal is a lifter but i have also been told it could be a bent rod. if its a lifter should i just replace all or just the bad one. and how would i do this or should i have a shop do it.
5.0, steeda short shifter, edelbrock intake upper and lower, bbk cold air intake, 3.73, b303 cam, 65 mm throttle body, 65mm mass air, 24 lbs injectors, h pipe, dual flows dump
and more to come
Old April 20th, 2009, 08:26 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
There is a very big difference between lifter/valvetrain noise and bottom end (rods) noise. Find someone that can tell the difference so you can determine what the problem is.
Old April 20th, 2009, 08:42 PM   #3
1988 Mustang
88Saleen is on a distinguished road
Send a message via AIM to 88Saleen
+ 1 bottom end noise is deff more of a solid sound rather just a tick like a lifter can make. if its just a lifter, if you have a general knowledge of the motor and pretty basic hand tools you should be able to do it. if you feel the least bit nervous either take it someplace or have someoen with mroe experience help.
Old April 20th, 2009, 09:00 PM   #4
1987 mustang GT
tomorrow im going to take it by the local shop to see if they can tell
and more to come
Old April 20th, 2009, 09:28 PM   #5
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
yea i mean if its something in the valve train it'll be a ticking if its a rod knocking its gonna sound some someone hitting the side of the motor with a hammer
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old April 20th, 2009, 10:17 PM   #6
89LX347's Avatar
89LX347 will become famous soon enough
do you have good oil pressure?
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old April 20th, 2009, 10:17 PM   #7
1987 mustang GT
its not really loud but loud enough to hear and its been doing this for about 6 weeks now. just if your on the driver side it sounds like its coming from and passanger and its the same way if your on the passenger side
and more to come
Old April 20th, 2009, 10:19 PM   #8
1987 mustang GT
yeah i got oil pressure about one min after the car starts and thats about the only gauge that works
and more to come
Old April 20th, 2009, 11:50 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
So you only have oil pressure after the car has been running for a minute????
Old April 20th, 2009, 11:58 PM   #10
Traidmarx's Avatar
1995 Mustang GT
not good, does the knock seem to go away after the pressure has built up?
Old April 21st, 2009, 12:31 AM   #11
MaroonNotchback408 is on a distinguished road
valve noise will be like a tick and rod knock is heavier and it even sounds worse.
Old April 21st, 2009, 12:33 AM   #12
1987 mustang GT
theres oil pressure it says a quature a way from the bottom for like a min but i think that has to do with the oil leak. bc right now i dont have alot of oil to any.
the knocking does quit down sometimes but it never goes away
and more to come
Old April 21st, 2009, 12:42 AM   #13
Traidmarx's Avatar
1995 Mustang GT
and you're still driving it around for 6 months like that...i dunno if its something in your bottom end or not but if your oil pressure is erratic like that i'm suprised you haven't thrown a rod yet. check the sending unit make sure its functioning properly.
Old April 21st, 2009, 01:29 AM   #14
91 LX
13.7@101
not sure why you wouldnt fill your motor with oil or why you would drive the car for this long and now ask about it....i hope you have something else to drive when your motor goes bye bye
Old April 21st, 2009, 01:36 AM   #15
Smirnoff's Avatar
1982 GT t-top
no proof of purchase
Smirnoff is on a distinguished road
if it leaks oil and you dont check it regularly theres a good chance its a bottom end knock not valvetrain
Old April 21st, 2009, 11:19 AM   #16
95StangMX's Avatar
95 Mustang GT
Um yeah I would say a ROD and it may be thats what wrong with the car too......little to no oil in it right now?....
Old April 21st, 2009, 12:50 PM   #17
JBIGBOOTSY's Avatar
1990 LX hatch
Does the car have a T-5, if so does the noise go away when the clutch is pushed in?
Old April 21st, 2009, 06:39 PM   #18
1987 mustang GT
not 6 months but about 6 weeks its been knocking. i do check the oil its just when its low the gauge say low oil pressure.
the noise seems to still be there even with the clutch pused it.
and more to come
Old April 21st, 2009, 09:50 PM   #19
Traidmarx's Avatar
1995 Mustang GT
wouldn't that be more of a whistling noise??
Old April 22nd, 2009, 09:53 AM   #20
91Project's Avatar
1991 Mustang GT
91Project is on a distinguished road
SERIOUSLY... Shut your freaking car off and quit driving it. You know oil is one of the most critical components to a motor yet your fine with driving around when its low? And by checking your oil regularly ( with a leak ) they mean to actually pop the hood and check it on the dipstick before you drive it. Dont wait for the dummy light to come on, ussually by then its too late.
AutoMeter C2 Nitrous Guage FS PM for details
Threads Similar to: motor knocking
Bad things...Motor Knocking SteviGX 99-04 3 October 9th, 2008 01:31 AM
knocking moosenuk17 99-04 22 April 29th, 2008 12:20 PM
knocking superbeef1000 99-04 10 October 14th, 2007 05:19 PM
1997 Cobra Motor knocking........ 1stcobra 96-98 17 March 15th, 2007 09:15 PM
Motor knocking :( ricer_slayer 5.0 Mustangs 5 February 26th, 2007 02:12 AM
