1988 Mustang GT Hatch
Alignment specs after a 5 lug conversion??
I just did a 5 lug swap using 95 spindles steeda bumpsteer kit and mm caster camber plates. What alignment specs should i use????
306, Edelbrock performer RPM Heads, Edelbrock Performer RPM 2 Intake, E303, Flowmaster Force 2 Cat back Exaust, H-Pipe no Cats, 373s, 24 Pound injectors, Cold air intake, 75mm Mass air meter, 70mm Throttle body,110 fuel pump,Ford underdrive pulleys |
12.9 @ 105
I used to do alignments about 5 years ago. I would probably stick with the specs for your car. The only thing that you might have to play with is caster. If your tires arent sitting centered in the wheel wells I would have them change those specs. Caster doesn't have to be in spec just make sure both sides are the same measurement. Caster camber plates will allow you to get all the specs dead on.
1989 LX coupe 5.0L
i had mine line'd up as a 95 but you have to watch one of the tie rods you cant turn it to much or the wheel will hit before the other one
03 GT, 92 coupe 2.3T
![]() iTrader: 3 reviews
Just have it aligned with the stock specs for your car.
Threads Similar to: Alignment specs after a 5 lug conversion??
| Alignment Specs | Rattltrunk | 2005 - 2010 | 13 | April 5th, 2009 01:20 PM |
| 2000 Mustang GT alignment specs | hammerlishooter | 99-04 | 3 | November 8th, 2008 05:51 PM |
| which 5 lug conversion | BWAL | 5.0 Mustangs | 16 | March 8th, 2008 04:59 PM |
| Alignment specs? | jivepepper | 99-04 | 1 | October 22nd, 2007 02:04 PM |
| 4 lug to 5 lug conversion questions | jharp59 | Classic Mustangs | 0 | June 10th, 2006 11:44 PM |
