Discussing Throttle Body in the 5.0 Mustangs Forum. whats a good throttle body for a stock mustang.......
Old April 21st, 2009, 04:57 AM   #1
1989Gt.'s Avatar
1989 Mustang GT
Throttle Body
Old April 21st, 2009, 09:02 AM   #2
dblzroracin's Avatar
BBK or Accufab 65mm throttle body & EGR. I have used both brands & never had a problem from either. The Accufab's may cost a little more but are polished & look nicer. most people also upgrade the mass air meter at the same time. Either a C&L 73MM or PRO-M 75mm mass air meter. The C&L meters are easier to upgrade later if you ever need to run bigger injectors.
www.bbandtracing.com
Old April 21st, 2009, 09:56 AM   #3
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Stock
Old April 21st, 2009, 10:24 AM   #4
Zippee is my step sister.
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Stock.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft
Old April 21st, 2009, 11:32 AM   #5
91 LX
13.7@101
there isn't any sense in buying a bigger throttle body for a stock mustang. buy gears, and fulll exhaust, etc.
Old April 21st, 2009, 11:32 AM   #6
95StangMX's Avatar
95 Mustang GT
Originally Posted by Arctic Fox View Post
Stock
agreed
Originally Posted by Darrell View Post
Stock.
agreed
the throttle body is not something you are going to change and see a difference in numbers in HP. It is a supporting mod that really needs to be done when you do your other mods like heads cam and intake etc. just putting a bigger TB on your car is most likely going to hurt your performance, but you should already know that cause you have someone who knows more than me working on your car
Threads Similar to: Throttle Body
99-04 Gt Throttle body g@232stang V6 Mustangs 6 March 20th, 2009 01:43 AM
Throttle Body goren420 V6 Mustangs 6 June 13th, 2008 02:14 AM
throttle body sk8flip67 99-04 5 April 15th, 2008 02:33 PM
new throttle body poof505 V6 Mustangs 15 November 4th, 2007 08:54 PM
throttle body noppe180 96-98 2 November 4th, 2006 06:57 AM
