WTF is up with my clutch
Last month I had the clutch setup fine, it would engage and disengage with no grinds, even though it engaged right off the ground..
Now when I try to put it in gear, it wont let me and just grinds.. so I thought the cable was loose.. Well the cable is all the way tight.. I can not possibly tighten it any more... Anyone have any ideas? I keep getting confused as how the whole cable setup works.. would a fire wall adjuster help or make the tight sitiuation worse?
weeee foooord!
does it grind all the time, or when moving, or when starting off in first?
you need to put your foot through the floor for it to fully engage? yeah mine used to be like that. i got a firewall adjuster, cable, and a ford racing aluminum quadrant and adjusted at the fork and firewall. mine is perfect
mine grinds in any gear.
Looks like ill need to put my adjuster on and see if that helps
weeee foooord!
1986 mustang gt
u still have the factory clutch cable plastic quadrant?
still factory quadrant yes.
It was a bitch to put on, so i just threw the cable on in hopes of getting it to a friends shop where he said he would put the quadrant on for me. I have a steeda triple hook somewhere.
weeee foooord!
Get rid of that factory clutch quadrant before you do anything else. Its not as hard of a job as it looks.
man i tried pulling it out, how the hell do I get those clips out??
I have to put a new throttle cable on as well
weeee foooord!
Removing the clips is the easiest part. They just pull off. If you pull the dash out it makes the job alot easier but it takes more time that way. I usually just recline the driver seat all the way and slide the seat back all the way. Then lay up side down under the dash. The job takes about 30 minutes.
#10 | |
1989 Mustang GT 5.0L H.O.
Pulling the dash will give you better access and you'll not have to play "acrobat" and stand on your head to get to it. If you don't think you want to tackel it then take it to a shop and give em' a few bucks to do the work.
#11 | |
1990 LX hatch
I just unbolt my seats to work on the quadrant.
85 GT/86 SVO/2010 GT500
+1 10 min to get the seat out 30 min to pull and replace the parts and that's with me get out once to throw up from laying upside down. That's at 6-4 265 not 5-8 and a buck 50
well my seat is out. and i can't take it to a shop to do it because my clutch wont engage in the first place.
But seriously, do I have freakin hulk hands or something? I do not see how the clips are the easiest part.
weeee foooord!
#14 | |
#15 | |
PeteAndersonRacing.com |
lol, i'll just quit bitching and do it.
I'm 6'2" 230... so that prooooolly doesn't help lol. I'll see if one of my friends will come over and do it for a 6 pack
weeee foooord!
1986 mustang gt
u aint gotta pull the dash. pull ur seat, lie on ur back, and use some long plyers to pull the clips. its doable and worth the trouble.
going to try it again tomarrow. Gotta find my quadrant, can't find it in the garage :|
thanks for the help guys.
weeee foooord!
Fuck quadrants.
I'm done. Clutch feels much better. Adjustments are in the middle on the cable end and firewall adjuster. I will forever pay people to put these pieces of shit in. /Rant
weeee foooord!
i hated it too
Threads Similar to: WTF is up with my clutch
| clutch replacement- replace whole clutch assembly or just clutch disc? | WilltheThrill | 4V / SVT | 12 | December 13th, 2008 12:18 AM |
| Centerforce clutch....ticking???? WTF | f0rdguy | 99-04 | 2 | December 23rd, 2007 06:50 PM |
| SPEC 3+ Clutch WTF! | 05mustang_TT_charged | 2005 - 2010 | 29 | December 7th, 2007 06:11 AM |
| WTF Is This? (Squeek From Clutch) | mustangmanic | 99-04 | 14 | December 4th, 2007 08:11 AM |
| Transmission? Clutch? WTF! | 95project | 94-95 | 3 | November 30th, 2007 11:59 PM |
