#21 |
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
i guess...so...wonder where i could find the measurements..? or if they would vary by manufactuer or eve what the measurements for a stock pulley is
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
#22 |
Look at them. Underdrive pulleys are obvious. If you are in doubt, post a picture.
#23 |
1995 Mustang GT
yea i can probably tell by looking i was just curious never paid much attention to it..but would underdrive pulley's cause the cooling issue i described as well??
#24 |
I don't see any problem with your cooling. The factory gauge is a guide at best. I wouldn't worry about what letter the needle is pointing at.
#25 |
^^^ True. Just swapping in a new sending unit can change the reading two full clicks.
The power window circuit is wired for 20 or 25 amps, just to give you an idea of how much current those old window motors draw. I just rewired mine to use the window motor circuit for my bottle heater.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#26 | |
12.8@103... stock motor
11.8@113...150 shot
#27 |
is that something in the alt or something else i could replace.....hasn't been doing it lately....can you link me?>
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#28 | |
In general, any time you do anything with the stock style Ford aleternator on the fox body, you should wire in a new pigtail and inspect at least the first two feet of those wires that run back to the battery. The design of that plug is crappy and uses two 1/4 spade connectors that are known to corrode and possibly catch fire or at least heat up and melt something. With the alternator hanging out on the bottom because of the Vortech, it is probably even more of a problem.
#29 |
i'll just swap out the alt i suppose
#30 | |
11.8@113...150 shot
if you have that style alternator do no replace the alternator without also replacing the connector!!! |
Threads Similar to: Question about my Voltage...
| Voltage Drops... | teal89 | 5.0 Mustangs | 3 | March 31st, 2008 12:43 AM |
| Voltage Problem | stang300a | V6 Mustangs | 22 | November 9th, 2007 02:44 PM |
| battery Voltage | new 5.0 | 94-95 | 3 | June 19th, 2007 09:38 AM |
| voltage regulator.. | espskillz | Classic Mustangs | 3 | August 7th, 2006 07:13 AM |
| Voltage Amp??? | My5point0Mustang | Audio/Video | 5 | October 20th, 2005 12:16 PM |
