Question about my Voltage...
Old April 21st, 2009, 08:54 PM   #1
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
i've had the issue since i bought the car just curious if anyone has had a similar problem. But the voltage is weird like if my windows are rolled up and i hit the button to roll them up again the voltage needle will drop waaaay down, the interior lights and headlights will also dim. It does the same thing with the windows down and rolling them down more. Sometimes if i have the bass turned up, the needle will fluctuate, other times i can just be sitting at a stop light or something and it'll drop down and the lights will dim, then as soon as i tap the gas pedal the needle shoots right back to the middle of normal. and the lights brighten back up. Any ideas?? I've had the alternator tested twice both times they said it was good, and the battery is about 2 months old.
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old April 21st, 2009, 09:27 PM   #2
1986 mustang gt
1fst5.0 is on a distinguished road
check ur alternator ur self with a DVOM. make sure u have ar least 13volts with all ur ususal electric accessories on. also make sure ur alt. connections r good, tight and clean. check ur battery cables too
Old April 21st, 2009, 09:31 PM   #3
Traidmarx's Avatar
1995 Mustang GT
k i'll check it
Old April 21st, 2009, 09:47 PM   #4
12.8@103... stock motor
11.8@113...150 shot
R0B0T can only hope to improve
i believe the ford alternators only put out a full charge at around 900 - 1000 rpms with stock pullies...
you're drawing too many amps when it does that, but if it doesn't kill the car i wouldnt quite worry about it unless you spend a long time idling, then you might need to give the gas pedal a love tap every now and then.
correct me if i'm wrong about the alternator...
Old April 21st, 2009, 10:10 PM   #5
Traidmarx's Avatar
1995 Mustang GT
yea i mean its never been a big issue or anything just something i was wondering about.
Old April 21st, 2009, 10:11 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The issue with the window switch is normal because there is an increased load on the circuit due to the window not being able to travel anymore. Every car does that. If you have an amp your bass problem is normal as well. If you have underdrive pulleys it will complicate things a bit more because the alternator won't spin fast enough at idle.
Old April 21st, 2009, 10:20 PM   #7
Traidmarx's Avatar
1995 Mustang GT
i don't have an aftermarket am i have the mach 460 system but not sure that would cause the voltage to fluctuate, and i don't have underdrive pulley's as far as i know. then again not sure how i could tell at this point.
Old April 21st, 2009, 11:17 PM   #8
nolife's Avatar
91GT, 88GT, 02GT
Like stated above, some fluctuation is normal. Larger than normal fluctuations are usually caused by a weak battery or bad battery cables/terminals. The alternator should put out about 13.8 volts. The fluctuating you see with big loads or quick large surges is the alternator getting loaded down until the voltage gets to the same level as the battery voltage. If your battery voltage is low because it is going bad or the terminals are dirty, the difference between the battery voltage and the alternator output are greater and the fluctuations are larger.
Old April 21st, 2009, 11:36 PM   #9
JonnyB is on a distinguished road
That sucks man. Wish I could help but im in the same boat your in. Im gonna check for a bad ground this weekend in hopes thats the prob. Anyway good luck gettin it worked out.
E303cam, hooker long headers, no cats, flomaster mufflers, mac CAI, A/C delete, c4 tranny w/shift kit, 3.73 gears, msd ignition, sub frame connectors
Old April 21st, 2009, 11:42 PM   #10
Traidmarx's Avatar
1995 Mustang GT
another thing i get is engine noise through my radio...but it comes and goes its weird.
Old April 22nd, 2009, 09:44 AM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Now that is not normal. That could be an alternator issue.
Old April 22nd, 2009, 11:09 AM   #12
95StangMX's Avatar
95 Mustang GT
engine noise "usually" comes from having a power cable too close to your rca cables or a power cable too close to speaker cables. TM I am betting you have pullies on that car I remember when you bought it you said it seemed a little faster than normal I bet it has a few things done and pullies are one of them.....the window thing is pretty normal but it shouldnt drop TOO far.
Old April 22nd, 2009, 06:22 PM   #13
1988 Mustang
88Saleen is on a distinguished road
Send a message via AIM to 88Saleen
i notice the same thing, and its because of the underdrive pullies. and, i have the same radio noise, but i just put in a CD and it all goes away. i think it might have something to do with possible spark plug wires. also could be from alternator, i never thought about it.
Old April 22nd, 2009, 06:28 PM   #14
Traidmarx's Avatar
1995 Mustang GT
i've got a video of it i'll post up tomorrow morning, it'll sometimes only drop down like like to the O in NORMAL sometimes it'll drop all the way to the N or a lilttle past it. How would i tell if i have pulley's on the car??? i don't see anything written on them. something else i've noticed and maybe this could be something else with the pullley's the temp gauge always reads a little warm...not overheating by any means but sometimes it'll travel on up to the A of NORMAL..could this be another thing caused by pulley's with the different pulley on the water pump. But i mean i guess pulley's are a possibility everyone that rode in or drove my car said it rev'd fast for a stock 5 liter
Old April 22nd, 2009, 10:08 PM   #15
1986 mustang gt
the buzzing noise can be taken care with a noise filter. check ur voltage at the alternator, then at ur battery. also rev ur motor to about 1500 rpm while ur checking.
Old April 22nd, 2009, 10:15 PM   #16
baine21225's Avatar
i dont mean to thread jack buuuuut, since were on a voltage thread i just want to slip in one question. about a week ago my cars volts were jumping from about 14/14.5 (normal) up to like 17ish for a bit, but if i took it out of gear for a minute it would drop back down, then if it got reved past 3k it would go back up again etc.....new cables, optima battery, is it my alt taking a crap? i think its prbly the stocker....i have a 3g waiting to go on it just looks like a pita with the vortech on there
Old April 22nd, 2009, 10:21 PM   #17
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
2 bolts baine and that alternator is off. Don't sweat it bro.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old April 22nd, 2009, 10:26 PM   #18
baine21225's Avatar
well then maybe i'll swap it over next week or so
Old April 22nd, 2009, 11:28 PM   #19
Traidmarx's Avatar
1995 Mustang GT
any ideas of how i can check to see if i have underdrive pulley's..??
Old April 22nd, 2009, 11:32 PM   #20
baine21225's Avatar
measure them?
Threads Similar to: Question about my Voltage...
Voltage Drops... teal89 5.0 Mustangs 3 March 31st, 2008 12:43 AM
Voltage Problem stang300a V6 Mustangs 22 November 9th, 2007 02:44 PM
battery Voltage new 5.0 94-95 3 June 19th, 2007 09:38 AM
voltage regulator.. espskillz Classic Mustangs 3 August 7th, 2006 07:13 AM
Voltage Amp??? My5point0Mustang Audio/Video 5 October 20th, 2005 12:16 PM
