High compression or Low?
Old April 21st, 2009, 11:45 PM   #1
MaroonNotchback408 is on a distinguished road
Whats are the pros and cons of each?? Is low compression with boost actually "better" but just more money?
Old April 21st, 2009, 11:46 PM   #2
91 LX
13.7@101
better. if you have too high of compression and boost your looking at blowing your motor.
Old April 21st, 2009, 11:56 PM   #3
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
well, alot of boost with high compression will build up to much cylinder pressure and cause the head gaskets to fail hopefully before anything bad happens. Low compression engines cost no more than high compression engines. Power adders can be had fairly cheap these days as well. They are for sale used all over the internet at crazy cheap prices. There a guy on the corral selling a cartech twin turbo kit for 3700 or 3800 I think. That's a hell of a deal for a power adder kit that will support over 1000rwhp. High compression with boost often runs into detonation issues also, must run hot gas in high compression engines. Even an engine with 9.8:1 compression will detonate under 15psi of boost with a 60mm single turbo. That's where you tune will come into play by retarding timing and adding fuel at the right time and the right amount of both.
Old April 22nd, 2009, 12:15 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Low static compression is what is needed in a boosted engine because the actual boost will raise the dynamic compression ratio. Dished pistons also give more volume to pack more air in the cylinders.
In a naturally aspirated engine low compression just lessens the efficiency of the engine. Higher compression is generally more efficient and creates more cylinder pressure which makes more horsepower.
Old April 22nd, 2009, 01:54 AM   #5
Ok so generally a high compression motor ( no boost ) is better then a low compression ( with boost )?
Old April 22nd, 2009, 02:12 AM   #6
89LX347's Avatar
89LX347 will become famous soon enough
wellll that comes with with many vairables. yes and no.
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old April 22nd, 2009, 10:35 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
Old April 22nd, 2009, 10:50 AM   #8
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
So, does Nitrous have the same effect as say a turbo or blower on a higher compression motor? For instance.... 10.5:1 comp. motor with 125 wet kit has the same odds as blowing a head gasket, piston ring etc, as a turbo or blower set-up @ 8-10PSI? Assumeing all combo's are tuned?
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old April 22nd, 2009, 10:54 AM   #9
JBIGBOOTSY's Avatar
1990 LX hatch
no, nitrous is fine for high to low compression. Heat and detonation are the general worries of n2o. Id say your odds are less likely with the n2o
Old April 22nd, 2009, 10:56 AM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No.
Old April 22nd, 2009, 11:53 AM   #11
91 LX
13.7@101
is your 331 a 10.5:1 compression motor? If so, (once you get your rear end issues and timing pointer issue figured out) you would be safe with a 125 shot, even more if you had the car tuned for it
Old April 22nd, 2009, 01:16 PM   #12
1998 Cobra
13.24@105.66
It's all in your timing and fuel trim..
People boost 10:1/10.5:1 compression engines (not really HIGH compression, but higher than most turbo setups would like) all the time.
The problem is detonation, so in counter to fix this, the fuel is increased so the cyl walls do not go lean and create a lot of heat, and timing is pulled also in effort to prevent detonation.
But there is a point to where a motor will have so little timing in it, that it wont run like it should. Running as much timing as possible with race gas is the best way to do it, but that's impractical lol
weeee foooord!
Old April 22nd, 2009, 01:43 PM   #13
nolife's Avatar
91GT, 88GT, 02GT
A decent opinion of the difference..
MotorSports Digest
Old April 22nd, 2009, 05:20 PM   #14
1988 GT
Yeah it's a 10.5:1 motor, Just wondering for future reference I guess. I might be able to afford a kit and wasn't sure if I should pick it up or not. But now I know, thanks.
Threads Similar to: High compression or Low?
Low compression vortech4.6l 96-98 0 October 4th, 2008 12:54 PM
Low Compression Pistons(10.1)... teal89 5.0 Mustangs 22 March 10th, 2008 09:15 PM
Low Compression High Boost? e3sean 5.0 Mustangs 19 November 19th, 2007 02:13 PM
High vs. Low Compression 87StangLX General Tech 14 November 17th, 2007 11:42 PM
Low compression and low Octane? brad65 5.0 Mustangs 5 July 28th, 2006 05:53 PM
