2001 Mustang GT
help i wanna make sure this is supposed to happen
so my mustang over heats i changed thermostat and just flushed the coolant and noticed a hi-cup in the motor as u see in the vide onece that cirlce thing spins the engine revs up a bit not a lot but u can hear an see it on the revs so just wanna see if u guys have advice???
<br> |
2001 Mustang GT
i wanna make sure that is supposed to happen lol
Thanks!! |
2001 Mustang GT
it comes on then as u see in the video it shuts off
Turn your defroster off.
I beleive that is your AC turning on. make sure you have it off and check it again
2001 Mustang GT
o yea i just realized it was on lol so its suppoed to go on and off?? and i just flushed my coolant and my car is trying to over heat i put coolant back in then i looked and its all moved into the overflow tank ??? ideas
it shouldnt cycle on and off, prob low on refrigerant.
is your cap releasing pressure properly?
It cycles on and off if your defroster is on or if you are low on refrigerant.
Does the car still over heat after you changed the thermostat?
2001 Mustang GT
well i dont knw about the cap 86er and i dont knw where to check if i need refridgerant and i changed the thermostat a couple months ago shuld i do it again and throw a higher temp one in ??? thanks again guys u guys a huge help
Threads Similar to: help i wanna make sure this is supposed to happen
| anyone bored and wanna make me a sig?? | joejoe8455 | Chopshop | 5 | March 20th, 2009 01:26 PM |
| Someone wanna make me a sig? | C MY 4D | Chopshop | 15 | January 1st, 2008 11:38 PM |
| I Wanna Make My 05 GT Loud | JiMMy..BriX | 2005 - 2010 | 27 | December 16th, 2007 04:57 PM |
| Wanna Make Me A Sig? | C MY 4D | Chopshop | 20 | November 26th, 2007 11:28 PM |
| Anyone wanna make me a sick sig??? | 04GTAMPA | Chopshop | 32 | September 27th, 2007 04:48 PM |
