tf topend kit
Old January 20th, 2007, 11:29 PM   #1
hmotes is on a distinguished road
tf topend kit
how much rwhp would i be at with the TF topend kit on a stock 302?
Old January 20th, 2007, 11:33 PM   #2
Wertzy's Avatar
Wertzy is on a distinguished road
Send a message via AIM to Wertzy Send a message via MSN to Wertzy
Which kit do you want to know about? Street or Track?
Old January 21st, 2007, 01:42 AM   #3
the street
but what exactly is the difference?
Old January 21st, 2007, 03:52 AM   #4
Wertzy's Avatar
Originally Posted by hmotes
the street
I think the track heat kit has different upper and lower manifolds. I could be wrong though.
Old January 21st, 2007, 02:26 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes the difference is the intake. I would suggest putting your own kit together because the cam they offer with the kit is a bit on the small side for the rest of the combination. I would run the Track Heat or R-series intake with the Twisted Wedge heads and the TFS-51402001 cam. I've made 320+ horsepower at the wheels many times with this combination.
Old January 21st, 2007, 04:05 PM   #6
89BEAR is on a distinguished road
Darrell,
How does the AFR 165'S and e303 match up or would you
suggest another cam for these heads as I head they are
awsome from quality to performance
Old January 21st, 2007, 05:34 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by 89BEAR
Darrell,
I'd use something a little bit bigger like one of the TFS cams.
Old January 21st, 2007, 06:11 PM   #8
ih8chevy is on a distinguished road
i kno someone who used afr 185's a custom ground cam with similar specs to the trick flow stage 2 and a some suspension work and was hittin 11's all day on the stock 302 block
Old January 21st, 2007, 06:57 PM   #9
Ask All My Baby's Mommas
lineumup88's Avatar
lineumup88 is on a distinguished road
afr 185's and a e-cam is a good combo. i have a friend that has this combo with a holley systemax intake that puts down 328 rwhp on a stock bottom end. there are a ton of good combos out there. shop around!
hey chevy boy.....i got something for you to POWERSTROKE!
Warning: surgeon general says its ok to smoke ricers!
Old January 21st, 2007, 09:50 PM   #10
this kit will be going on the stock bottom end. I want to be able to just install the kit without having to notch the pistons. Also this car is my daily driver.
Old January 21st, 2007, 09:58 PM   #11
5-0stank is on a distinguished road
Darrell, im looking to use the cam you mentioned in my 351w roller along with the r-series intake and twisted wedge heads. will the cam be ok with the stock pistons and 1.6 rockers? also, do you know what length pushrod i will need w/ these heads?
thanks
1995 GT::Sold!
Looking for another stang...
Old January 22nd, 2007, 05:09 AM   #12
Is there a big difference to ported cnc heads in hp gains? I
was looking at TF and AFR with a litttle
heavier cam, but hard to find a good combo when there are so
many choices. Anyone have suggestions
Old January 22nd, 2007, 05:28 AM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've run the TFS stage 2 cam on many stock short blocks and never had to notch pistons.
Old January 22nd, 2007, 05:30 AM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
thanks
Should be ok but you should always check valve to piston clearance. Buy a pushrod length checker to determine what length pushrods you need. That is the best way to do it.
Old January 22nd, 2007, 05:31 AM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Yes there is a big difference. More airflow equals more power, always. An internal combustion engine is nothing more than an air pump. Air in, air out equals horsepower.
Old January 22nd, 2007, 08:51 AM   #16
So, if I go with TF twisted wedge heads CNC porting and stage 2
TFS cam, this would set up well. Could you recommend the TF heads
I would need being ported and assembled so all I have to do is
basically bolt them on and go. I appreciate your help
Old January 22nd, 2007, 09:08 AM   #17
JBIGBOOTSY's Avatar
1990 LX hatch
Trick flow heads are one of the only 2.02 valve heads that work on a stock 87up bottom end.
Old January 22nd, 2007, 03:13 PM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If you are going to spend the money on the CNC ported heads I'd spend the money and get a custom cam from Cam Motion or Camshaft Innovations.
Old January 22nd, 2007, 07:40 PM   #19
Thanks Darrell and I have sent cam motion an email.... can
they custom fit a cam for the setup I am describing without
giving them exact specs?
Thanks
Old January 22nd, 2007, 11:08 PM   #20
so i should run the kit with the stage 2 instead?
