Bad vibration on 1989 Mustang GT
Old April 23rd, 2009, 05:00 AM   #1
Mistertribal's Avatar
1989 Mustang GT vert.
Mistertribal is on a distinguished road
I noticed that I have a bad vibration on my car especially when I decelerate from approx from 80 to 65 mp/h and it feels like I was driving on the "rugged" band on the side of the road which is not the case...I don't feel this vibration on lower speed like 60 mp/h and less in lower gears though...I have new tires, freshly balanced and aligment just done...Any ideas of what could cause that problem??
Keep pursuing your dreams...'cause when you stop...you die.
1989 Mustang GT convertible
Dynomax Ultra Flo 2.5" catback, BBK 2.5" O/R H Pipe.
Old April 23rd, 2009, 06:02 AM   #2
1989 LX coupe 5.0L
89lx is on a distinguished road
did you check your u joints? did you have the vibration before the new tires?
Old April 23rd, 2009, 08:09 AM   #3
hopper is on a distinguished road
usually the problem at that speed is either the wheel bearings or you shifted a belt inthe tires.
Old April 23rd, 2009, 10:22 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
When did the problem start? Possible causes are tires, u-joints, driveshaft out of balance........just like the other guys mentioned.
Old April 23rd, 2009, 11:18 AM   #5
91 LX
13.7@101
i have a vibration in my shifter and clutch pedal at high speeds...: ( it bugs the heck out of me
Old April 23rd, 2009, 01:59 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Transmission bearings.
Old April 23rd, 2009, 02:04 PM   #7
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
Do you have 3.73 or 4.10's ?
Old April 23rd, 2009, 02:28 PM   #8
No I haven't check my U joint, it is the one that came with the drive shaft with my T-5 conversion kit and I have no idea how old it is...
I think the problem started after the new tires and/or after I had the car aligned...
I feel this vibration in the shifter also especially in 5th gear...
I have 2.73...
Old April 23rd, 2009, 02:32 PM   #9
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
i'd def. check the u joints mine would vibrate horrible at any speed above 40 mph and around 80 mph it would shake the shit outta the car. put new joints in and it rides like a new car.
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old April 23rd, 2009, 02:35 PM   #10
Should I change the U joints first and if it doesn't solve the problem then change the drive shaft??
Old April 23rd, 2009, 02:36 PM   #11
Traidmarx's Avatar
1995 Mustang GT
well you can have the driveshaft checked to make sure its balanced....like someone asked before do you have gears??? see if you can get under the car and see if the drive shaft has alot of play in it...if it does then its the U joints.
Old April 23rd, 2009, 02:45 PM   #12
Ok I'll go check it out and as I said in a previous post, I still have the original 2.73 gears...
Old April 23rd, 2009, 02:52 PM   #13
Traidmarx's Avatar
1995 Mustang GT
i missed that my bad..
Old April 23rd, 2009, 02:55 PM   #14
No prob..!!
Old April 23rd, 2009, 04:46 PM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I have 2.73...
The first thing to do is make sure all of the lug nuts are tight. If they are all tight and the problem started after the new wheels and tires then take it back to the shop that did the work and tell them the problem you are having and that they need to fix it.
Old April 23rd, 2009, 06:52 PM   #16
I will for sure.
Old April 23rd, 2009, 06:58 PM   #17
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
I would also check the driveshaft bolts. They tend to back out if you don't tighten them enough.
TT Build in progress.......
Old April 23rd, 2009, 07:22 PM   #18
91 LX
13.7@101
is there any other way of telling if my bearings are bad?
Old April 23rd, 2009, 07:28 PM   #19
Thanks bro...I'll have a look at it also since we had to remove it to change the imput shaft seal recently...The bolts might not be tight enough...that makes a lot of sense...Thanks again...
Old April 23rd, 2009, 07:53 PM   #20
Threads Similar to: Bad vibration on 1989 Mustang GT
Went From 2.3 to 5.0, but get bad Vibration thedeadlyghost 5.0 Mustangs 13 March 3rd, 2009 11:27 PM
Bad Vibration From The Rear? STANGDOOD 5.0 Mustangs 21 October 25th, 2008 04:22 PM
My 1989 Mustang GT stangfreak The Clubhouse 58 March 24th, 2008 06:21 PM
1989 mustang gt zincsvtcobra 5.0 Mustangs 13 March 19th, 2008 10:27 AM
