Anyone Running Cobra R's on a fox step in....
i just bought a set used for my fox.
They are 17x9's fronts have 245/45/17 rears are 275/40/17 wanting to see what others are running TIRE WISE I put the rear tires on and they hit the quad shock. Well more of rub. So I am going to reverse the quad shock. I was told to do this from the guy I bought them from. ANYONE ever reversed there quad shock? I need NEW tires up front. The ones that are on the wheels up front are pretty much shot. Why are the front 45 series and the rear 40 series. Was wondering should I put 45s again up front or go with 40's like the rear.
1989 mustang GT 5.0
#2 | |
The reason the aspect ratio of the tires is different is to keep them closer to the same height. A 245/45-17 is roughly the same height as a 275/40-17. If you put a 245/40-17 on the front it would look retarded and the tire wouldn't have any sidewall to it.
makes sense to me. Thanks Darrell
I'll get pics up as soon as I reverse the quad shock and get everything all said and done. Now I'm on a mission to price new tires for the front. And I already know the fronts rub if you cut the wheel alllllll the way. Anyway around that. Or just don't turn the steering wheel as much?
1989 mustang GT 5.0
#4 | |
i have the exact same tire set up on my car. i never had a problem with rubbing with my 555R's out back, but when igot my BFG drag radials they are wider and i had to flip the quad shocks and do some tapping to the inner fender well so they dont rub
1993 5.ohhhh
12.97 @140mph
I have the same rim and tire combo front and back. My fronts rub when I cut the wheel. I have no turning radius anymore, and my rears rub whenever I hit a bump. Mine are mickey t's and my car is slammed.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
yeah it's cause your car is lowered. My fronts never rub
1991 5.0 LX
I'm running black cobras but have 17x8 on the front and 17x9 in the back, I run 255/40/17 all around with no problems, though I did have to flip my quad and could not longer use the new KYB quad shocks I was using I had to go back to stock ones.
why did you have to flip your quads with a 255? thats weird..i would get wheel spacers or something so the KYB would work
1991 5.0 LX
My KYBs didn't fit so for some reason I thought my stocks wouldn't fit the regular way either...and since then I have been take 21 credit hours of college each semester and 12 credit hours every summer and just haven't had time to mess with it again. To be quite honest, I actually just never thought about getting wheel spacers though. I will be looking into that.
1992 Lx
11.39@119.24
look at my garage
On my lowered 88, I have 235/45 on 17x9 on Cobra clones and they rub before full lock in the front. I don't know the exact backspacing so I guess you can't really directly compare.
I had a problem with them on my stock 91 as well but I don't think it was from arm rubbing, I think maybe the strut was hitting them during quick direction changes, maybe my upper strut bushing is worn out.
do the front tires on yours seem to stick out to much just a bit. Wish I had 17x8's up front. Might fit a little better. The 17x9's just seem to be a little to much for up front. I had to buy all 4 do I just took em. Still better than turbines.
do the front tires on yours seem to stick out to much just a bit. Wish I had 17x8's up front. Might fit a little better. The 17x9's just seem to be a little to much for up front. I had to buy all 4 do I just took em. Still better than turbines. I gave $450 for all everything. THe back tires are good the fronts were shot. you think $450 was a good deal?
1989 mustang GT 5.0
1990 5.0 LX SSP
Get some of those plastic bushings to go on your rack.That will limit the amount of turn radius so your tire won't rub.
SVTfocus, F250
I have with a 245 555r on front - tight turns they rub. They dont stick out and look wicked.
Back has 275 Nittos with no quad - never rubs. Pics : Haggis13's 1993 Ford Mustang GT
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
1985 Mustang GT
those are what im running on my '85. 5lug conversion. no problems
Threads Similar to: Anyone Running Cobra R's on a fox step in....
| Cobra R's | SLNGT2007 | 2005 - 2010 | 6 | October 29th, 2010 03:22 PM |
| New Cobra R's FTMFW!! | 510jatt | Pictures | 13 | March 20th, 2009 02:39 PM |
| Here are my new Cobra R's | Drtbkercr5 | Pictures | 17 | April 10th, 2008 02:14 PM |
| too many cobra r's..... | 232stang | The Clubhouse | 18 | May 31st, 2007 10:32 PM |
