oil in intake plenum
So im replacing the gaskets between my upper and lower intake, and i took the cover off of the edlebrock upper intake, and there was a puddle of oil in there. just wondering if thats normal or bad? if so how do i fix it? thinking about removing EGR, does that mean i need to turn my fuel pressure up at all?
Normal. Not good, but normal. On hard acceleration the oil runs to the back of the lifter valley and is sucked thru the PCV valve into the upper intake. No need to remove your EGR. It isn't going to gain you anything.
1993 5.ohhhh
12.97 @140mph
Darrel, would putting a check valce somewere help this? I've taken my upper mani off several times and it should be clean as a whistle. But like Darrel said it happens.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
#4 | |
Don't you have a blower on your car flatty? If so then you shouldn't be using a PCV valve. Pressurized crankcase is bad news.
1993 5.ohhhh
12.97 @140mph
Yessir. I'm not familiarized with pcv systems at all, and I need some edumication on that. BUT, by pressurized do you mean boost going back in the motor through my crank case vent?
Yes. Use breathers instead of a PCV.
what about fuel pressure? do i need to turn it up any because i dont have EGR? it should it not make that much of a difference?
#8 | |
Even then you will be successfully making your wallet lighter and not making anymore horsepower or any benefit.
Threads Similar to: oil in intake plenum
| Painting the Intake Plenum | rugbyman00 | 2005 - 2010 | 21 | February 20th, 2008 09:37 PM |
| Intake Plenum | jbm5781 | 96-98 | 2 | August 20th, 2007 06:34 PM |
| Intake Plenum | Mustang Mike | 99-04 | 10 | July 28th, 2007 06:28 PM |
