Non HO motor into 91 Mustang
Old April 24th, 2009, 05:17 PM   #1
Devilman's Avatar
1985 GT
13.01@105.10
Devilman is on a distinguished road
I am putting a temporary 5.0 into a 91 GT Mustang out of an 88 Marquis. I have all the stuff off the Mustang to put on the Marquis motor. I know the firing order is different. The question...Can I get by placing a 531W flat tappet camshaft into it? This should correct the firing order problem. I just want to make sure the injectors fire correctly and that the distributor gear will work. I am being a cheapskate as I don't want to spend the extra money to put the roller lifters in it also (89 bucks vs 300 bucks). thoughts?
"Pain will always be there, misery is optional....."
Old April 24th, 2009, 05:22 PM   #2
Wtf..........is it really hard for people to find an 302 HO roller block.......... Find 80 of them here for 100 bux....
Dont turn you car into some redneck mobile
PeteAndersonRacing.com
Old April 24th, 2009, 05:57 PM   #3
Devilman's Avatar
1985 GT
13.01@105.10
It ain't mine. Its "family" and I am trying to get the stuff out of my yard cheap as possible as I am sure I will foot the bill and the time......Your Point is well taken though.....back to the original question, I should be able to put the 351W shaft in it and send it dowm the road?
Old April 24th, 2009, 09:51 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
+1
Old April 24th, 2009, 09:51 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Why don't you just buy a 302 HO? A non HO 302 isn't going to be much if any cheaper than a HO 302 and buy the time you swap cams like you want and all of the gaskets that go along with it you will have more money into the non HO 302.
Old April 27th, 2009, 12:08 PM   #6
Devilman's Avatar
1985 GT
13.01@105.10
I found a 91 GT camshaft, pushrods and lifters on craigslist. I'll just swap out the cams and drill the bosses for the spider, no biggie. I was asking more from a technical prespective in case anyone knew why the 351W camshaft wouldn't work. I have done it in the past on carb engines but didn't know how bad it would screw with the EFI on later model engines. All the parts mentioned is stuff I got laying around. I have two roller engines sitting in my shop. I didn't want to get rid of them for free if I can make the 88 motor work........
Old April 27th, 2009, 01:06 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Swapping a 351W cam will work.
Threads Similar to: Non HO motor into 91 Mustang
motor 65 mustANG rxnodoze02 Classic Mustangs 2 May 13th, 2008 01:23 PM
'05-'07 mustang motor W/T-56 SoCal67mustang 2005 - 2010 6 December 25th, 2007 01:31 AM
New Mustang Motor W/T-56 SoCal67mustang Classic Mustangs 1 December 24th, 2007 03:10 PM
Mustang motor FastBack71 5.0 Mustangs 3 January 30th, 2007 06:37 PM
