cooler plugs
Old January 21st, 2007, 10:58 AM   #1
cdunc24's Avatar
cdunc24 is on a distinguished road
cooler plugs
what do the heat ratings on plugs mean and how does it affect performance?
"It's the fastest who gets paid...
and it's the fastest who gets laid"
- Reece Bobby
Old January 21st, 2007, 11:00 AM   #2
cdunc24's Avatar
sorry, in case it wasn't clear, spark plugs
- Reece Bobby
Old January 21st, 2007, 02:17 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The heat range is the plugs ability to dissapate heat. Engines with high compression or power adders (nitrous, turbo, supercharger) need colder heat ranges. As far as a performance gain, there is none. You won't gain any performance from just changing heat ranges.......but running the correct heat range will prevent you from having a pile of melted aluminum in your oil pan.
Threads Similar to: cooler plugs
cooler mpboy 99-04 3 October 15th, 2007 10:52 PM
Radiator: Car Needs to Run Cooler BoomerSixZero Classic Mustangs 23 September 20th, 2007 06:42 AM
Transmission Cooler? Garhfer 99-04 1 September 15th, 2007 02:02 PM
Transmission Oil cooler Mustang Mike 99-04 1 March 5th, 2007 09:41 AM
C4 Cooler lines New88MustangOwner 5.0 Mustangs 4 December 6th, 2006 09:21 PM
