short belt
Old April 25th, 2009, 12:50 AM   #1
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
short belt
I had an 84.5" belt on my fox because my smog pump seized. It's been squeaking and I realized the tensioner was all the way down and the belt was bouncing on the part between the alternator and the harmonic balancer. I put in an 83.5" and its all good. Just wondering if anyone else had this problem because I know everyone runs the 84.5 but it was too long for my car.
Old April 25th, 2009, 02:19 AM   #2
Vamp89's Avatar
1989 Mustang GT
Vamp89 is on a distinguished road
I have a 77 inch
Ported Saleen Vortech Intake
BBK 70mm t/b,BBK CAI,BBK Reg,BBK 255 Fuel Pump
Hooker Super Comp Long-tube Headers
Fcam
Ported Motorsport J302 Heads
30# Injectors
1.6rr
80mm Mass Air
4:11 gears
Old April 25th, 2009, 02:40 AM   #3
Chris951's Avatar
1991 mustang 5.0
wtf with the smog bypassed?
Old April 25th, 2009, 03:09 AM   #4
No bucks, no Buck Rogers
Notcho's Avatar
Notcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to beholdNotcho is a splendid one to behold
Send a message via AIM to Notcho
I run an 82-1/2" belt... No smog pump, Belt is around the A/C, power steering, alt, waterpump and crank... the crank pulley is underdrive, not sure about the others. One of the previous owners did that.
Gates part # K060820 for the 82.5" belt.
'87 2.3 Notch with +4 cylinder mod
MM's Resident Aggie
Black Stang Crew Member #11
Old April 25th, 2009, 11:01 AM   #5
Vamp89's Avatar
1989 Mustang GT
Yeah
Fcam
30# Injectors
1.6rr
80mm Mass Air
4:11 gears
Old April 28th, 2009, 04:32 PM   #6
87 CAVALLO is on a distinguished road
Anyone Know The Size For The Belt When Removing The A/c Compressor New To Thismustang Thing 87 Mustang 5.0 Conv.
Old April 28th, 2009, 06:33 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You can't just remove the A/C, you need to relocate the power steering pump or the belt will rub when it crosses itself above the water pump pulley.
Old April 28th, 2009, 10:02 PM   #8
Notcho's Avatar
Or you can get one of those A/C delete kits.. it comes with a dummy pulley that fits where the A/C compressor used to be.
Some people actually use these dummy kits when they remove the smog pump. I don't, but some people claim the smog pump or smog pump dummy pulley relieves extra tension on the alternator bearings.
The power steering pump relocation would keep it cleaner under the hood as well as reduce rotating mass though. Probably the best bet.
MM's Resident Aggie
Old April 29th, 2009, 12:24 AM   #9
1986 mustang gt
1fst5.0 is on a distinguished road
i took off my a/c and smog pump. it didnt rub, but does come close. i drilled a new hole in the alt. bracket for the tab on the tensioner so i could rotate it and put more tension. i eventually got an alt. kit( from march) with a tension bar and it looks awsome.
Threads Similar to: short belt
Short Belt Results jerrytubbs1 2005 - 2010 3 April 19th, 2009 03:05 PM
Short Belt Length ThreeHonks302 5.0 Mustangs 19 March 24th, 2008 07:49 PM
Short Belt Size shadowgames81 5.0 Mustangs 2 January 25th, 2007 08:44 PM
MMR Short Block vs DSS Short Block superbeef1000 99-04 6 September 20th, 2006 05:49 AM
short belt size please chadjones99 5.0 Mustangs 7 August 21st, 2006 05:16 PM
