1989 Mustang GT
Car Won't Idle
Been awhile guys but I'm having issues with my car, it runs but won't idle and dumps fuel like crazy no matter what we do. Changed every sensor went through 3 different mass air meters and injectors changed computers and engine wiring harness but not the dash/firewall harness yet. Can anyone help with this I don't wanna carb it but it is looking that way. Thanks
![]() Ported Saleen Vortech Intake BBK 70mm t/b,BBK CAI,BBK Reg,BBK 255 Fuel Pump Hooker Super Comp Long-tube Headers Fcam Ported Motorsport J302 Heads 30# Injectors 1.6rr 80mm Mass Air 4:11 gears |
1991 mustang 5.0
Did you check fuel pressure?
1989 Mustang GT
Set right now at 42 running 24# injectors
1992 Lx
11.39@119.24
try 38
1991 mustang 5.0
42 seems a little high..
1992 Lx
11.39@119.24
how do you know its dumping fuel like crazy?
You sig says 30 injectors and now you have 24? Did you swap or recall the MAF sensor to match the 24 injectors?
Check you FPR vac line and see if fuel is leaking by.
1989 Mustang GT
Yeah we switched injectors and mass airs and you can smell the gas when its trying to idle
1989 Mustang GT
We ran the 24s at 36 and it was to lean so we went to 42 , it runs great but when it hunts for that idle it's screwed
1989 Mustang GT
Disconnected MSD box put stock coil back on idling at 900 :-)
#11 | ||
Let me guess, the MSD box was mounted under the hood in the engine compartment?
Threads Similar to: Car Won't Idle
| what does your car idle at?? | o2gtstang | 99-04 | 46 | March 3rd, 2009 08:33 AM |
| my car at idle.. | jat | 2005 - 2010 | 4 | November 10th, 2008 11:19 AM |
| Problem starting my car (won't idle) | Reset | 99-04 | 25 | May 24th, 2008 01:19 PM |
| Car Wont Idle | 1BADSTANG | 5.0 Mustangs | 2 | December 4th, 2007 08:37 PM |
| car wont idle | bluedemon | 5.0 Mustangs | 2 | February 2nd, 2007 06:13 PM |
