Proud American
Steering Issue in my 351 build
Well my steering wheel is not straight when the wheels are lined straight. So I tried to fix that today. Could not get it done.
Another issue is, the car will turn really hard to the right (passenger side) but wont turn to the Drivers side much at all.. Anybody had a similar issue? the wheel has been like that since I put in my K member and had the rack off... Any remedies?
1991 mustang 5.0
When my tires are straight, the 12 o'clock on my steering wheel is at about 2 o'clock. It's annoying but it's been like that since I bought it and I've never really looked into fixing it...
1991 mustang 5.0
Justed searched on google and came up with something about setting the toe by screwing the tie-rod end sleeves and running the tie-rod ends in or out.
#4 | |
Proud American
No, my car doesnt have an engine/ tranny in it yet... the K member is lined up and straight though, I have had the stock K member down and put back up prolly around 7 times. And the Team Z went up with nothing out of the ordinary on that. The steering rack though has never done this...
RIP Travis Billings ![]() Special Thanks to: Andrews Racing Transmissions Baseline Suspensions 25.3 SFI Chassis Build Never Lift Racecars Last edited by MustangMatt96GT; April 26th, 2009 at 01:19 AM. |
I think i may have your same problem, I pulled my steering column to put my quadrant in, and now that I remember, the wheels were cocked, well i moved the wheels in by pushing one wheel in, but my column was locked, so now it only turns to the left a little bit it seems.
weeee foooord!
#7 | |
1. your steering rack has never done this 2. you put in a tubular k member 3. your steering is messed up now.
Proud American
I don't think it's k member related. I will do a back yard alignment though and see from there... Might just buy a manual steering rack. I'll see what comes from a tape measure alignment.
No, its not realated to the K-member. Was your rack centered when you installed it or was it a half a turn or so to one side or the other? Either way it needs an alignment. I wouldn't worry about the tires or anything pointing straight right now because it doesn't matter. You can't drive the car anyway. Once you get everything else done on the car then take it down for an alignment.
yeah do a tape measurement, atleast that would show if it's totally screwed up.
I saw some flaming river manual racks and knuckles going for 259 for wholesale on ebay.
weeee foooord!
Take the steering shaft off with the wheels straight. Straighten your steering wheel, while everything is straight, put the steering shaft back on.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#12 | |
Proud American
Im not worried about my steering wheel not being straight (its a race car) but I am worried about not being able to turn left very much... Would an alignment cause that issue too? Matt
#13 | |
Proud American
Threads Similar to: Steering Issue in my 351 build
| Power Steering Issue | TomRob77 | Classic Mustangs | 3 | April 13th, 2009 06:39 PM |
| here is my issue | bigbadwollfff04 | Drag | 35 | July 5th, 2007 09:34 PM |
| t5 issue | 342stroker | 5.0 Mustangs | 3 | June 4th, 2007 09:41 PM |
| Decreasing power steering pump pressure for tighter steering | 83 5.0 | 5.0 Mustangs | 6 | January 7th, 2007 08:24 PM |
| 1972 Mustang Conv. BOSS 351 or 351 HO? | 72BOSS351 | Classic Mustangs | 1 | October 8th, 2006 05:12 PM |
