Hideing the factory harness/relays/etc. in fenders
I would love to see some pics of anybody who has hid the harness in the fenders. Im gunna start extending the harness tomorrow and would like to hear some tips/advice of anybody who has done this. I guess im going to label everything at the sensors or clips and pull the harness out and re-route the harness in the fenders. Im also going to take out the windshield washer resivor and put the starter relay and all those wires that hook up to it in the fender as well. id like to see some pics to make sure the end look is going to be worth the trouble. Im guessing im just going to cut the wires, extend them by soldering them and useing shrink tubeing to cover the solder joint. any objections w/ my plan? Oh and if I just disconnect the battery will I be ok, or is there capacitors holding any juice to any wires in the harness? I dont want to short anything out by cutting all the wires up in my wireing harness.
Proud American
Word of advice... dont put the soleniod in the fender... its then a PITA t time the car or do anything that has to be hooked up to the battery... if you have a relocation kit...
I put mine in the fender, but I can easily movie it to the stock location without extending any of these wires, just a matter of preference really!
weeee foooord!
your probably gonna get frustrated but its worth it.
heres mine. ![]()
i think it looks good when you wrap the wires with electrical tape that matches color of other things in your car like blue tape to match the spark plug wires and cai
imo
if you were on a bicycle and we were going up hill i could beat you in a race |
ha your inner fenders look like swiss cheese. Have any plans in the future for filling them?
who cares about shaved engine bays, doesn't make it any faster lol
weeee foooord!
I have run the wiring thru the fender many times but never took pictures.
![]() Its fairly simple. Take your time and solder all connections. Its nice to get the wires out of the engine compartment. It cleans things up a bit.
1988 lx
9.68@142
BEFORE
![]() your right who would want this. AFTER
Your engine bay is mint Sean! I love it!
Wow. Nice under hood^^^^
1988 GT
I Didn't have to do any cutting and soldering, just take off the old wire loom and re-wrap everthing... Here's mine though. I'll find a "Bay" picture when I get back from work, Sean everytime I see your engine bay I Jizz a little. fyi.
Damn sean i agree with the dude above. I kinda got a hard on looking at your engine bay. Im definitely going to do it now. I did notice your water pump bypass. how u have it looped back into the other tube on the water pump. Can I do that if im not useing a heater core anymore? The water temp sensor is on the stock rail that one of the bypass hoses ties into correct? If i just put a water pump gague and tie it into the front driver side intake mainfold, is that all ill need to do to get rid of that stock coolant rail that runs along side the intake manifold? I did notice your panels you made just in front of the strut towers. Did u just use one piece of sheet metal with a slight roll towards the bottom, weld it in place and bondo it? It looks great like that. Ive seen some people that have just made a panel at the bottom and notched it out but it looks a lot easier the way it appears in you pic. Great job man! I have no idea why someone posted " why would u want to shave the engine bay", it looks freaking beautiful!
bump. water pump bypass looping back into water pump on seans photo. can I do that if not useing a heater core?
I'd cap the return and run the other one to the bypass in the intake. It will help the engine warm up by circulating coolant before the thermostat opens.
Newblet
1987 GT
When you put the wires in the fenders wouldnt it make it a pain in the ass if you ever had an electrical issue and had to check wires? Or just work on the electrical at all
1988 lx
9.68@142
like he said that pic is not updated i fixed it and i got an adaptor for my coolant temp sensor
Threads Similar to: Hideing the factory harness/relays/etc. in fenders
| fenders | rliberte | V6 Mustangs | 2 | January 3rd, 2009 07:48 PM |
| Z3 Fenders | gsjohnson | 99-04 | 35 | January 23rd, 2008 01:50 AM |
| Relays | wraitherx | 5.0 Mustangs | 10 | December 10th, 2006 02:15 PM |
| Fenders | 88Horseman | 5.0 Mustangs | 2 | November 28th, 2006 09:48 PM |
