pcv valve or not.. hm
Old April 26th, 2009, 02:34 AM   #1
1998 Cobra
13.24@105.66
On my current setup, I have two breather filters and a pcv valve running to the carb..
Since my valve covers are cheap chrome ones and are leaking, I would like to put a stock set of h.o. valve covers on it..
But the stock valve cover doesn't have a pcv setup, just a straight hose.
Think it will matter if I don't run a pcv? Not like my car is going to idle worth a shit anyway lol
weeee foooord!
Old April 26th, 2009, 10:43 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Breathers + PCV = vacuum leak
You need to run some sort of crank case evac whether it be a PCV or breathers.
Old April 26th, 2009, 11:44 PM   #3
1998 Cobra
13.24@105.66
So either cap off the large vac port on the carb and run breathers or run sealed valve covers with a pcv valve correct?
weeee foooord!
Old April 27th, 2009, 12:33 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
correct
Threads Similar to: pcv valve or not.. hm
pcv valve gooberhead320 General Tech 2 August 27th, 2008 02:57 AM
pcv valve? 40thmustanggt 99-04 23 June 11th, 2008 10:03 PM
PCV valve I_eat_rice 99-04 2 April 9th, 2008 04:42 PM
Egr Valve And Pcv Valve Delete? Jeffery9508 V6 Mustangs 16 January 28th, 2008 09:45 PM
Where Is It? (PCV Valve) cobraetti General Tech 3 August 6th, 2006 09:16 PM
