? for ppl using nitrous
Old April 26th, 2009, 01:17 PM   #1
mikegilbert810 is on a distinguished road
How do u keep ur timing in check when spraying and when n/a, is it ok to run NA with the recommended 4' retard for a 125 dry shot or do I have to time the car every time? will the car feel slow when not spraying with retarded timing ? And is there any way to have ur timing adjust auto between the spray being activated -4' and stock timing when not spraying? Thanx
Old April 26th, 2009, 01:58 PM   #2
92sspnotchback is on a distinguished road
Yes, you can run the car without spraying with the timing retarded, it will just be a little sluggish. Or, you can bump the timing back up when not spraying. MSD makes a timing box that retards the timing automatically, but I have never used one, so I cannot tell you much about them.
Old April 26th, 2009, 02:05 PM   #3
so do u run with it retard or just adjust it every time?
Old April 26th, 2009, 02:09 PM   #4
also I run out of 4th in the 1/4 at 108 mph with 410s would 373s give me enough room to stay in 4th with a 125 shot say at 118-120 mph pass
Old April 26th, 2009, 10:13 PM   #5
ryans88gt's Avatar
^^^ What size tire.
With a 26 inch tire and 3.73s you should be able to get to 120 mph before hitting the limiter in 4th.
Old April 26th, 2009, 10:44 PM   #6
89Domindart's Avatar
89mustanglx5.0
89Domindart is on a distinguished road
Send a message via AIM to 89Domindart
I dont think I had to retard my timing when I ran the nos. I think I have a cam or something. My car always ran good when I wasnt running the nos. Ill have to check this out and see what my timing is set at.
looking for a mustang again.!
Old April 26th, 2009, 11:10 PM   #7
89LX347's Avatar
89LX347 will become famous soon enough
wow, thats good advice
i have the start/retard MSD box on my car and it is activated when the full throttle switch for the nitrous is activated
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old April 26th, 2009, 11:21 PM   #8
e3sean's Avatar
1988 lx
9.68@142
if you get your car tuned and chipped you can get an adjuster switch like i have it has 8 selections on it and all i do it turn it between tunes for what i am doing and it will make the car run completely different. they can even put a valet mode so it wont go over a certin rpm so if you bring it somewhere they cant romp on your car.
<font size=4><b>MILITARY CREW
Old April 26th, 2009, 11:32 PM   #9
1998 Cobra
13.24@105.66
hell yeah, no one will be pulling a ferris bueler on you lol
On my nissan i made multiple maps..
Street (7psi)
Strip (14psi)
Lean burn (emissions)
Highway map (lean, pulled timing)
and full open loop map in case a sensor went nutso (i burned up 02's all the time)
As for the poster I would run a retard ignition box, safest way to go.
If you do not pull any timing it could(and prob will) hurt some ring langs and say bye bye to your pistons
weeee foooord!
Old April 27th, 2009, 12:08 AM   #10
89mustanglx5.0
wasnt giving advice , just stating how my car ran..
Old April 27th, 2009, 10:07 PM   #11
hahaha that is funny as hell... I wish I could afford one of them but right now I'm strapped for cash, my main concern was if running the colder plugs and retard timing if it would hurt anything, if not I'll just stick with that and maybe when I save up some quid I'll get the msd.
Old April 27th, 2009, 11:25 PM   #12
91 LX
13.7@101
get a timing light and just retard it when you are going to run spray....until you can get a chip/tune or MSD box
Old April 27th, 2009, 11:40 PM   #13
89mustanglx5.0
ya retard it
Old April 28th, 2009, 09:51 AM   #14
chriswao's Avatar
1989 mustang gt
8th 5.70
chriswao is on a distinguished road
retard 2 degrees for every 50 hp of nitrous and you can do that with a msd box or by a light. not hard but dont listen to people when they say not to take any timing out because you'll hurt your motor. Do two or every fifty and youll be ok.
Originally Posted by Dennis View Post
great thanks i think i just lost 50 points off of my IQ reading that
Old April 28th, 2009, 10:07 AM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
One step colder plugs is all you will need and they will be fine for normal driving as well. Timing is easy. Retard it before you spray. Then move it back to normal when you are not spraying.
Old April 28th, 2009, 10:15 AM   #16
chriswao's Avatar
1989 mustang gt
8th 5.70
+1 darrell
do that or get the box.Its not gona hurt the motor riding around with it retarded but you wont have the power.
Old April 28th, 2009, 10:30 AM   #17
91 LX
13.7@101
yeah...im the type of guy that wants the most power as i can so I would always be changing my timing if i was spraying. but i have the SCT 4 bank chip so i will just switch tunes when i have nitrous on my car ; )
Old April 28th, 2009, 11:02 AM   #18
Proud American
MustangMatt96GT's Avatar
Yet curious... I will be running 110 through my car at all times.... I an going to have a locked out distributer. What would a good timing be for a 100 shot? With the higher octane, I was thinking of around 34 degrees locked out. Advice?
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old April 28th, 2009, 11:53 AM   #19
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If it was my car I'd leave the timing alone with race gas and only 100hp of nitrous. I've only sprayed 100hp a handfull of times but I've never taken any timing out with such a small amount of nitrous because I was running good fuel and because it is such a small amount. If you want to be super duper safe then pull 2 degrees out. But I guarantee if you spray it on the dyno you will see no detonation with good fuel and no timing pulled out.
Old April 28th, 2009, 11:57 AM   #20
Proud American
So what timing would you recommend to start my motor at? I knowi will have to play with it at the track, but whatwould be a good starting point? 11.5 compression351 with a world Windsor sr head 850 carb.
RIP Travis Billings
Special Thanks to:
Never Lift Racecars
Threads Similar to: ? for ppl using nitrous
i hate ppl deedub97GT The Clubhouse 20 February 23rd, 2009 10:06 AM
how do you rep ppl 00redgt The Clubhouse 3 November 7th, 2008 12:49 AM
TO the military ppl obdnanr The Clubhouse 15 April 24th, 2008 03:52 PM
ppl who know the internet.. MSO The Clubhouse 8 September 29th, 2007 12:54 PM
