Rod and Main cap torque questions
Old April 26th, 2009, 02:40 PM   #1
foxbdy88's Avatar
1988 Mustang GT / 98 Expo
foxbdy88 is on a distinguished road
I just got my engine back and assembling it and my haynes manual says the ending torque on the rod caps are 36 ftlbs and 85 ftlb on the mains i got stock bolts. Ive read that the mains are to be at 60-70ftlbs and the rods are to be 24 ftlbs which does seem a bit light to me....
LMK
thanks
mods list:
Balanced 306, Cobra intake, GT40 heads, TFS1, 1.6 RR's, 70mm TB, 73mm ProFlo MAF, BBK shorties, OR/H pipe, Flowmaster American Thunder cat back, 3:73's, MAF Conversion, CAI, A/C and Smog deleted,
Old April 26th, 2009, 03:04 PM   #2
89LX347's Avatar
89LX347 will become famous soon enough
it depends on what bolts you have and the grease/lube you use
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old April 26th, 2009, 05:12 PM   #3
foxbdy88's Avatar
Im using stock bolts and using Moly engine assebly lube
mods list:
Old April 26th, 2009, 06:38 PM   #4
86er's Avatar
if its stock bolts, use stock specs.
Just a truck
Old April 26th, 2009, 10:34 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
LMK
thanks
60-70 ft/lbs on the mains and 24 ft/lbs on the rods is correct if you are using stock hardware. More torque on them is going to do more harm than good.
Threads Similar to: Rod and Main cap torque questions
Questions about FRPP Hot Rod cams War Machine 115 2005 - 2010 127 August 6th, 2008 06:51 PM
Teksid Main cap tq specs HMStang217 99-04 0 January 20th, 2008 06:22 PM
1996 GT Tie Rod Torque thetechnocrat 96-98 1 January 8th, 2008 11:51 AM
Dart Aluminum 351W main stud torque teamssr Racer's Corner 1 February 3rd, 2007 10:07 PM
