burned two oil pumps?
Old April 27th, 2009, 01:02 AM   #1
sniperrider's Avatar
sniperrider is on a distinguished road
Send a message via MSN to sniperrider
after rebuilding the motor and installing a new oil pump both my new pumps have seized. Both have lasted about two miles before noticing oil pressure drop and shutting the car down. I reused the stock pick up but cleaned the hell outta it with the air nozzle from the compressor I took the first seized pump off and tore it apart to find absolutly nothing wrong with the inside besides the fact that its seized what could cause this? The stock oil pump drive shaft and a heavy duty high volume shaft have both twisted and snapped any ideas? Im lost and very irritated
90 lx hatch
Old April 27th, 2009, 01:21 AM   #2
anyone any ideas why this keep happening to me i am going to just buy a new pick up and go for lucky number three but wanna make sure there is nothing i can look at before i do it again its not the most enjoyable repair to do...lol
90 lx hatch
Old April 27th, 2009, 01:42 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
What kind of pumps are you buying? I'd definitely get a new pick up just to be safe.
Old April 27th, 2009, 01:47 AM   #4
i tried a melling and clevite the other one they tried to give me was sealed power, i have been getting them from schucks
90 lx hatch
Old April 27th, 2009, 01:51 AM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Get a standard volume Melling and a new pick up. Get an ARP shaft while you are at it too. Maybe get it from different store as well. Eliminate all possibilities.
Old April 27th, 2009, 01:57 AM   #6
yea well i had the arp shaft on the second pump and it snapped right at the bottom but i sent it back to summit as a defect and i will pick those up in a few days and let you know how it goes. thanks for the advice
90 lx hatch
Old April 27th, 2009, 10:16 AM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You broke an ARP shaft????? Impressive!
Old April 27th, 2009, 10:48 AM   #8
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
I had a melling put in my last motor and it took a shit in the dyno room all over everything some kind of spring trouble the shop said it has happened two or three times in the the last couple years and basicly the shop has to eat it so your not the only one.
Old April 27th, 2009, 01:18 PM   #9
yea that makes me feel better lol i just having rough time. but the arp shaft held up through its thick point but snapped the second it pretruded from the little crevice in the oil pump. ill see if i can get a camera on it the stock shaft looks cooler all twited lol apr is just a quarter inch too short
90 lx hatch
Old April 27th, 2009, 02:01 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I've twisted up a stock shaft once when using a hi volume oil pump. It was cool looking, but the engine damage wasn't.
I also broke a generic Sealed Power hardened shaft when the Sealed Power pump locked up after about 20 miles on the road.
I've had good luck with Melling pumps though. I always use a standard volume pump though. No need to pump all of that extra oil to the top of the engine.
Old April 27th, 2009, 02:57 PM   #11
ryans88gt's Avatar
Check for pump/shaft/dizzy gear binding. Only thing I can think of.
Old April 27th, 2009, 03:48 PM   #12
alright i got a camera and once i find batteries ill take pics and ill check the dizzy
90 lx hatch
Threads Similar to: burned two oil pumps?
I just burned myself. Dansby The Clubhouse 2 December 31st, 2008 07:23 PM
So i got burned again . . . 707Stang The Clubhouse 21 March 4th, 2008 12:23 AM
What pumps do I have??? duel pumps, see pics jdslyrbullitt 99-04 1 February 26th, 2007 10:16 PM
Billit Oil Pimps vrs GT and Cobra Oil Pumps WAR-PARTY 99-04 2 August 22nd, 2006 01:55 AM
