Hmm.. oil catch can
Well I had a brain fart before, i was running open breathers and a pcv valve, and that wont work, so I was thinking about getting another set of valve covers that do not have breathers, only pcv valve locations.
Could I just run two pcv valve and then run hoses to a catch can? That way Ill at least have some kind of vented breather system going. I also have a set of stock ho valve covers I would use if I can. Any issues with 1.7 rockers and how could I do the pcv setup on that as it only has one breather tube off the oil filler neck.
weeee foooord!
what's your setup? are you forced induction or ?
That won't work. PCV valves need vacuum to operate or the check valve inside will stay closed. You can run hoses from both valve covers to a breather tank like this Moroso tank. Moroso 85466 - Moroso Vacuum/Dry Sump Breather Tanks
no forced induction, all motor
weeee foooord!
#5 | |
Darrell to the rescue. I think im just going to run my stock H.O. valve covers and since it has a tube comming off the oil fill, I'll run that hose to a catch can. That way its vented.
weeee foooord!
what's wrong with the stock setup? Are you sucking oil into the intake.
I'd probably just go with breathers.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Too small. Its going to be hard to breath thru that small tube. At least get a screw in breather for the valve cover. I know K&N makes one....or made one anyway. I have one. If you can't find anything let me know and maybe I'll send you the one I have if you cover the shipping.
Yeah, they still make them. I had one on my 89.
+1
Threads Similar to: Hmm.. oil catch can
| Which oil catch can do you use? | bkid | 2005 - 2010 | 17 | April 16th, 2009 12:51 PM |
| DIY oil catch can. | texas_mustang | 2005 - 2010 | 59 | March 14th, 2009 11:52 AM |
| Oil Catch Can | 97mustanggt | 4V / SVT | 10 | February 11th, 2009 11:41 PM |
| Do I need a catch can? | flattusmaximus78 | 5.0 Mustangs | 6 | February 2nd, 2009 11:40 PM |
| where can i get a cheap blowby oil catch can? | Bandit | 2005 - 2010 V6 | 8 | May 23rd, 2008 12:56 PM |
