AFM quick kit II
What do you guys think of this anderson top end kit? I have prety much all the bolt ons i will need to buy injectors, MAF, and a TB to go along with it. That is a damn good price and I will have a lot of dyno time to tune it just right...maybe by the end of the summer put a little nitrous to it.
85 GT/86 SVO/2010 GT500
Do you have a link?
Anderson Ford Motorsport Home Page it is under 86-93 power packages quick kit II high rev
That looks like a killer deal and Andersons stuff seems to always put out good results
for sure....i mean...i love the idea of high rpm's. I am going to freshen up the bottom end of my engine while im in there...I think it should be a pretty nasty little 302
1988 GT
That does seam like a real reasonable price. Especially with a worked bottom end, you should be extremely happy.
1992 Lx
11.39@119.24
seems like a good kit if you clean up that intake mani, my friend bought one and had to spend alot of time cleaning up all the casting flash inside of it, other than that im too cheap to buy new heads
so you really have a mach one? you are so lucky dude. and yeah i plan on having a friend help and doing some port work to that intake. you can take that side plate off for easier access
#10 | |
1992 Lx
11.39@119.24
yeahhhhand its a copy of my edelbrock performer i just put on the fox (like an idiot) id get the performer rpm2 if you wana rev, this manis rated idle-5500
look on AFM's website. they say the prof products is good to 6500..i mean look at that dyno chart from the kit. i am going to see what it does, but I plan on getting that new edelbrock pro flow xt Edelbrock.com - EFI - EFI Manifolds - Ford
once i have the $$
#12 | |
Here is what happens when you buy cheap rocker arms.
i was wondering about that company name....ill switch out rockers. the intake will be fine i will end up selling the intake and the rockers to make a little money back when i have enough for the pro flow xt by edelbrock
Sounds like money being wasted to me. Why don't you just buy a Trick Flow kit or better yet, build your own kit?
because i dont think i could piece together a kit for that price. trick flow top end kits dont make the power that the AFM kit does
I made 326rwhp at about 5900 rpm with the Trick Flow K514-360-350 kit and the TFS-51402001 cam in place of the TFS-51402000 cam that comes in the kit. The AFM kit is showing 321rwhp. If you piece something together and have a cam ground for your combination then you could see 340+.
what heads come with that kit? are they like 170cc or 190cc...i always forget what sizes TFS goes by. Maybe I will do that..
170cc
hmm...i just checked out that cam you ran....that does look like a nice cam. you think i can put down 330-340 with the TFS top end kit and that cam? hmmmm
Don't know, like I said before I made about 326rwhp with that set up. If I did it again, I'd probably go with the 190cc as cast head or the CNC185 head and a Jay Allen custom grind.
Threads Similar to: AFM quick kit II
| Used AFM PMS tuning issues | FivePointSlow777 | 5.0 Mustangs | 2 | April 17th, 2009 02:48 AM |
| AFM cold air MAF and stuff | Iwannagofast | 5.0 Mustangs | 22 | January 2nd, 2009 06:22 PM |
| Top End Kit AFM or Trick Flow | rvdooley | 5.0 Mustangs | 5 | November 12th, 2007 07:22 PM |
| Walbro & AFM Big Pump | Zak | 5.0 Mustangs | 5 | February 17th, 2007 10:31 AM |
