relay??
Old April 28th, 2009, 12:30 PM   #1
92hatchback's Avatar
92hatchback is on a distinguished road
relay??
alright so i took my fuel pump relay out to check if its bad. But i have no idea what to look for to see if the relay is bad i have it sitting in front of me. so if anyone could let me know what to look for it would be great. should i just replace it with a new one??
Old April 28th, 2009, 12:38 PM   #2
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
when your car is off do you still hear the fuel pump cycling? or when you turn the car to the "on" position do you hear the "whirring" sound of the pump?
if any of these 2 you answered yes then your relay is bad.
for the first question the reason why it would stay on is because the relay acts like an automatic switch, when power is applied to one end of the relay the electromagnet pulls the internal switch over to the position to turn on that accessory. if it is staying on then that means that when power is taken away the electromagnet is still getting energized not switching the internal switch, or the internal switch just stopped working and is stuck in that position
same thing applies for question 2, where this time the electromagnetic switch is not being pulled over to the position to cut the pump on.
easiest way to tell if it is working is to plug it back in, turn the car to the on position, and listen for a "clicking sound". if nothing is hear then it is bad.
BUILD 2 IN PROGRESS
Old April 28th, 2009, 12:44 PM   #3
nope the pump does not prime when the key is in the "on" position. I think it is actually the pump but i wanted to check the relay and the inertia switch before going into surgery on the pump. But it seems like the relay is fine and the intertia switch is not popped or anything..
Old April 28th, 2009, 12:47 PM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
if thats the case then if you have a multi-meter you can check the wires to see if there is power going down that line to the pump before you drop the tank. this way you are certain that it is the pump and not a fuse or something a little more simple.
I ran into the same problem when i had my 89
BUILD 2 IN PROGRESS
Old April 28th, 2009, 12:50 PM   #5
yea im gunna go pick one of those up, figure its good to have anyways.. thanks for the help.
Old April 28th, 2009, 12:56 PM   #6
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
no problem
BUILD 2 IN PROGRESS
Old April 28th, 2009, 01:25 PM   #7
91 LX
13.7@101
isnt it normal for the fuel pump to whine for a few seconds when you turn the key on?
Old April 28th, 2009, 01:39 PM   #8
yeah but mine isnt whining at all. now i have the multimeter. does anyone know what wires to test, kinda dumb when it comes to this electrical. dont know how to use this thing either haha
Old April 28th, 2009, 02:59 PM   #9
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
yeah its letting you know that the pump is priming
BUILD 2 IN PROGRESS
Old April 28th, 2009, 03:00 PM   #10
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
let me see if i cant pull up something and ill get back to you (if someone else doesnt in the mean time.
BUILD 2 IN PROGRESS
Old April 28th, 2009, 03:10 PM   #11
Moderator
wraitherx's Avatar
'99 SVT Cobra
iTrader: 11 reviews
ive got to go through all my old stuff to see if i cant find the diagrams to send to you. also, it still can be the relay as if its not priming then it could be an indication that the internal mechanism is no longer functioning. have you tried listening for a click, or better yet hold the relay, turn the car on, and you should feel something move inside. just a thought.
try and get another relay to plug in they are only like 5 dollars
BUILD 2 IN PROGRESS
Old April 28th, 2009, 03:22 PM   #12
1998 Cobra
13.24@105.66
should have continuity..
then apply voltage and the other side should have continuity.
weeee foooord!
Old April 28th, 2009, 08:05 PM   #13
its fine now. i just said screw it and changed the pump and it works now.. thanks guys.
Threads Similar to: relay??
What relay do i need baine21225 5.0 Mustangs 8 March 16th, 2009 04:57 PM
need quick relay help 91cobra5.0 5.0 Mustangs 13 February 4th, 2008 02:12 PM
a/c relay on 1986 GT 1st fox body 5.0 Mustangs 0 January 6th, 2008 06:01 PM
Relay akatagyourit 2.3 Mustangs 2 July 21st, 2007 12:39 PM
fuel relay Mustang RacR94 V6 Mustangs 3 April 15th, 2007 05:24 PM
