starter woes..
Old April 28th, 2009, 04:29 PM   #1
1998 Cobra
13.24@105.66
starter woes..
well guys still trying to iron out the bugs in my project..
Starter was working fine up until a few days ago... backed the car out of the garage and left it outside.. then when i went to fire it up again, battery was dead, so i put the battery charger on it, i heard a hard knock sound and it would just spin the motor over and not fire it, with that same knock sound.. it eventually fired but the starter is super loud and scratchy sounding now..
well the this morning i spun it over and it still had that whine to it, but fired right up.. ran it for a few minutes .. shut it off..
Now I went to start it, the starter spins super fast but just makes that scratchy sound and wont turn the motor over.
I have tried tapping on the solenoid and the stater motor with a hammer thinking maybe it wasn't kicking out.. no luck from that.
What I'm thinking is that the battery charger was at like 18v or whatever and it spun the starter hard enough that it burnt up or broke a tooth off it. What you guys think?
btw, the motor is nothing special, just standard roller motor bottem end, so it doesn't deal with high compression or anything. Also I did not have a 5 speed mounting plate for my trans, so I cut the stater section off of it, and found some washers within .002 of the same thickness and used those. Think the starter is shimmed incorrectly?
weeee foooord!
Old April 29th, 2009, 08:06 PM   #2
1998 Cobra
13.24@105.66
anyone? The starter sucks to pull because i have to take my header off to do it, any advise as what to try with it on the car?
weeee foooord!
Old April 29th, 2009, 08:28 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Who knows, pull the starter and look at it. Its probably junk. They don't last forever.
Old April 29th, 2009, 10:39 PM   #4
1998 Cobra
13.24@105.66
true but this starter was new when I put the motor in, cranked the car maybe 25 times?
I have the starter shimmed, think i should take them out?
weeee foooord!
Old April 29th, 2009, 10:55 PM   #5
1986 mustang gt
1fst5.0 is on a distinguished road
where did u get the starter from? do u have long tube headers?
Old April 29th, 2009, 11:16 PM   #6
1998 Cobra
13.24@105.66
Its an autozone starter.. yes i have long tubes.
weeee foooord!
Old April 29th, 2009, 11:24 PM   #7
1986 mustang gt
autzone, checkerauto....not the best starters and alternators. i bought a "new" starter to install when i did my clutch, i went to start it when i finished, and nothing, not even a click. so u usually roll the dice with starters and alt. but they do go out with or without warning. but in ur case, u got plenty of warnings.
Old April 30th, 2009, 01:06 AM   #8
ryans88gt's Avatar
Sounds like the bendix is binding or hitting the flywheel. You need shims on the outside half of the starter only.
This is of course a random guess based on my recent experience.
Old April 30th, 2009, 10:47 AM   #9
chriswao's Avatar
1989 mustang gt
8th 5.70
chriswao is on a distinguished road
youve prob messed the fly wheel up buy now.
Originally Posted by Dennis View Post
great thanks i think i just lost 50 points off of my IQ reading that
Old April 30th, 2009, 10:53 AM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It takes alot to mess up flywheel teeth with a softer metal bendix on a harder metal ring gear.
Old April 30th, 2009, 12:18 PM   #11
chriswao's Avatar
1989 mustang gt
8th 5.70
not all the time ive seen a starter get out of line when a bolt comes loose and eat it to hell and back
Old April 30th, 2009, 01:57 PM   #12
1998 Cobra
13.24@105.66
The outside half of the starter?
weeee foooord!
Old April 30th, 2009, 01:59 PM   #13
1998 Cobra
13.24@105.66
True..
Bolts are still all snug and the starter hasn't cocked yet. When I pull it off, ill roll the motor around and check the flywheel and make sure it's ok.
At least I have a steel flywheel, so the chance that it will get messed up is alot less likely than if it was aluminum (alum flywheels usually have steel teeth, but still alum is softer than steel).
weeee foooord!
Old April 30th, 2009, 08:06 PM   #14
1998 Cobra
13.24@105.66
The starter is screwed .. the mounting tab broke off!!
So the starter was cocked and stayed moving while the car was running burning out the bendix.
Would it be ok to run a starter without a backing plate (my tranny backing plate is an auto with the starter section cut off to fit)
weeee foooord!
Old May 1st, 2009, 04:50 PM   #15
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
People have run without that plate but realistically it is not ok. That plate provides proper spacing for the starter and also the torque converter (or input shaft in a manual). If it was just a dust shield like everybody thinks, it would just bolt to the lower bellhousing and not go between the block and bellhousing.
Threads Similar to: starter woes..
Starter solenoid clicks at the starter but wont start the car?? 95StangSVT 94-95 13 March 11th, 2010 10:22 PM
My woes zinc02GT The Clubhouse 26 December 26th, 2008 08:11 PM
Tuner woes. RAGEman 99-04 19 April 23rd, 2008 11:05 AM
Longtube woes. RAGEman 99-04 17 March 31st, 2008 11:48 PM
Starter or Starter Relay cobralini 5.0 Mustangs 7 August 3rd, 2006 06:34 PM
