89mustanglx5.0
air comes into my car next to the shifter
I need a way to insulate the area aruond the shifter . I was thinking about car audio insulation, to keep that hot air from getting up into the shifter area, and also It would deaden the sound too,no? what do you think would be good for this?
looking for a mustang again.! |
Atomized
i use dyno matt in mine two layers it works great
spray and pray |
1990 LX hatch
I just stuffed a hefty garbage bag around the shifter.
89mustanglx5.0
lol I think Ill look for some dynamat and see how that works.
I think I had some foam padding in there that worked, but Ill try dynamat this time
Get a new lower boot.
1993 Mustang GT
Saving up for another one
Yeah i think it would be better to just replace the boot.
I had the same problem on a 86 5.0 i used to have. The hot air blowing into the cab of the car turned out to be a blessing in the winter time cause the car's heater didnt work
89mustanglx5.0
^^ haha
thanks for that link, though it doesnt look like it would fit my hurst shifter, ill try dynamat, it may also work good to deaden the sound from the outside too
Yes it will fit a Hurst shifter.
Atomized
I have a lower boot on mine and the dyno matt. I hate the noise and the heat.
spray and pray |
89mustanglx5.0
I actually think the rubber boot arund it now burns- I smell a bit of rubber sometimes, but I dont know if its that boot or what.
Threads Similar to: air comes into my car next to the shifter
| can an auto shifter(aftermarket) for an 05-08 work in my car? | o2gtstang | 99-04 | 9 | March 29th, 2009 01:57 PM |
| Is it normal to hear more 'car noise' after installing a new shifter? | vomitron | 2005 - 2010 | 12 | January 19th, 2009 05:39 PM |
| New car that runs on air | timberwolf | The Clubhouse | 26 | November 3rd, 2008 10:19 PM |
| 2 mods - K&N cold air intake and short shifter. What ne | VT-Stang | 2005 - 2010 | 16 | July 25th, 2008 04:27 PM |
| Car Air Freshener | Garhfer | The Clubhouse | 14 | June 10th, 2008 01:27 AM |
