Need to know serpentine belt size
I dont ahve one installed, and I have a 4.5" once and a 7" diameter pulley. Its a 93 notch with an 86 carbed 302. with PS, water pump, alternator, and tensioner pulley. Also Im missing one of the bolts to mount the pulley, so does auto parts/partsource have crank pulley mounting kits?
The 4.5 is probably an underdrive pulley. I believe the stock pulley is 7". Bolts you should be able to get anywhere.
so im assuming i should put the 7 inch on? And do you knwo where/what the elngth of the belt I need is?
heres a pic, I dont have the tensioner pulley housing put on yet, The alternator has been moved over as well
Threads Similar to: Which crank pulley?
| my crank pulley!! | Imran | 99-04 | 27 | April 1st, 2009 07:45 PM |
| crank pulley | flattusmaximus78 | 5.0 Mustangs | 0 | August 1st, 2008 04:01 PM |
| BBR 2.57 Pulley and 10% Overdrive Crank Pulley | raycutchins | 2005 - 2010 | 1 | May 26th, 2008 06:23 PM |
| crank pulley | mikedoogen | Modular Mustangs | 3 | June 20th, 2007 01:22 AM |
| crank pulley help | mikedoogen | 2005 - 2010 | 3 | June 19th, 2007 01:17 PM |
