seat problem
hey guys, so today i noticed my seat was moving around a little more than i like it to on the left side rear bolt. so i got home and looked at it, thinking the bolt was loose or broken at worse. well my whole floor is loose... what am i looking at to fix this? i really dont want it to be flexing like that, things are going to get weak and break.
Atomized
thats because your torque boxs needed to reinforced. It's gunna be pricy to fix unless your a welder
spray and pray |
1990 LX hatch
Huh?
#4 | |
Look under the car and see how bad the floor is torn. Easy fix with a welder.
ok well, the floor board is not torn. it is moving by the rocker panel. so idk if maybe its just a tack weld or something. but the floor is not torn.
Post a picture.
i had one of my front studs break off the other day getting into the car, its like riding a rocking horse when i drive now....adds to the thrill of the drive
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
alright, i got some bad news!!
the floor pan is torn, i just could to see it, and its not really that large thats why i couldnt find it before. i took my seat out today, and i have a 4" tear in the floor board. the tack welds that hold the floor to the rocker are also broke, tommorrow im going to a local welding shop and having them weld it back together, and possibly sub frame connectors. from there i will build my own seat brackets to strengthen the floor pan where it tore before.
#9 | |
and a note on the subframe connectors, makes sure you get fell length weld in, or even threw the floor type
full length is just a length of 1x2 inch tubing connecting the front to the rear right? or what do you mean by full length? i would like to do in floor's but i dont think im there yet.
Threads Similar to: seat problem
| Power seat problem need help!!! | bullitt01 | 99-04 | 7 | December 27th, 2008 11:33 PM |
| 124105 Apc Race Seat? I Need A Seat Asap Which Will Fit A Budget | 1911A1 | 5.0 Mustangs | 1 | December 13th, 2008 06:37 PM |
| ford seat covers or any seat covers | asiantat21 | Visual | 14 | June 7th, 2008 08:06 PM |
| 2005 Seat belt problem | wormster00 | 2005 - 2010 | 19 | October 24th, 2007 01:27 AM |
| problem finding seat belt/airbag alert buzzers | cuttlebearman | 2.3 Mustangs | 2 | April 18th, 2007 04:41 PM |
