backfiring back threw the carb
Old April 29th, 2009, 06:42 PM   #1
cobra911 is an unknown quantity at this point
hey guys
just had a friend rebuild my carb from an 85 302 H.O. original carb, when i went to start it , it started and idles on low idle and then when i went to give it gas it fire balls threw the carb.
Any ideas? thanks
Old April 29th, 2009, 07:51 PM   #2
1998 Cobra
13.24@105.66
have you changed timing at all?
Sounds like a lean fuel misfire.. have you adjusted the carb at all for accel pump or idle circuits..?
weeee foooord!
Old April 29th, 2009, 08:29 PM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Timing, EGR and a few other problems cause this. When did it start doing this?
Old April 29th, 2009, 08:44 PM   #4
1985 Mustang GT
viperlocc is on a distinguished road
if you changed nothing BUT the carb rebuild, i'd say your friend fucked up
Old April 29th, 2009, 08:46 PM   #5
no i didn't change timing or adjust
Old April 29th, 2009, 08:48 PM   #6
i plug the egr
the car sat for 5yrs resealed the enging didn't touch timing
and after the carb rebuild
Old April 29th, 2009, 09:16 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by cobra911 View Post
i plug the egr
Sounds like your friend screwed up a carb rebuild.
Old April 29th, 2009, 11:28 PM   #8
1986 mustang gt
1fst5.0 is on a distinguished road
yeah, get another rebuild kit and knock it out urself, not that hard
Threads Similar to: backfiring back threw the carb
carb buildup in Plenum and back off throttle body adrenaline=lifeline 99-04 2 July 25th, 2008 03:22 PM
Backfiring ...again Somebody Help! blakehunter316 5.0 Mustangs 1 April 6th, 2008 11:47 PM
My Stang is backfiring! WombRaider 5.0 Mustangs 10 October 30th, 2007 09:15 PM
Backfiring 00vabchgt General Tech 6 June 19th, 2007 08:56 PM
Backfiring 00vabchgt 99-04 0 May 24th, 2007 04:26 PM
