fuel woes :(
Old April 29th, 2009, 10:55 PM   #1
PolishSasquatch is on a distinguished road
fuel woes :(
Noticed I have a leak int eh rear, looks like its right after the fuel filter. Most likely its the seal between the two tubes. (so do I need new hoses or what?) Also I notced when I was was tappign the gas pedal the engien would sputter. So could it be part throttle circuit problem? (its an 85 4bbl v8). Heres a pic of where its leaking.
Secondly, the car had the alternator moved over, should I just bring ti back to stock position (dont know if regular sized belt will fit on it)
Old April 30th, 2009, 12:21 PM   #2
wow lots of help here
Old April 30th, 2009, 02:11 PM   #3
baine21225's Avatar
well it sounds like you answered your own question, if its a seal, then fix a seal....if its the hose then fix the hose
"Whip out your dick you'll either get it sucked or get smacked..."
Threads Similar to: fuel woes :(
My woes zinc02GT The Clubhouse 26 December 26th, 2008 09:11 PM
Nitrous woes zerofx150 99-04 7 April 25th, 2008 02:48 PM
Tuner woes. RAGEman 99-04 19 April 23rd, 2008 12:05 PM
Seatbelt Woes. RAGEman 99-04 13 December 7th, 2007 08:42 AM
new here, idle woes knskit 5.0 Mustangs 36 February 20th, 2007 04:44 AM
