#21 |
that way usually works better with v belt and pullies but serp belt will work to
#22 | |
#23 |
Works better and v-belt don't belong in the same sentence.
#24 |
i used the alternator switch bracket I had and ordered a 49.5" belt and works great so far. Now Gotta figure out my coolant issue...
#25 |
once you have enerything where you want it you can take your stock belt, cut it so it is one long piece, run it through all the accessories and when u go over the one end pinch it there and tape it. take that taped belt to discount and they can put that on a belt size checking tool. just make sure they dont look at the number on the belt and give you a stock belt. make sure they measure your taped belt. I did that when i got rid of my air pump and ac comp. i just had to build a bracket for the tensioner and move it. I didnt want to have to use or buy aip pump or ac comp delete pullies.
Threads Similar to: [help]Take a look at my pulleys...wtf?
| Idler Pulleys Underdrive pulleys? | 96GtGoodz | 96-98 | 4 | November 19th, 2007 11:02 AM |
| UD Pulleys | Monster90 | 99-04 | 6 | November 13th, 2007 06:07 PM |
| pulleys | CBSTANG | 99-04 | 2 | June 5th, 2007 12:46 AM |
| so i got my pulleys | mustang1072 | V6 Mustangs | 49 | May 29th, 2007 12:15 AM |
| pulleys | mustang1072 | V6 Mustangs | 16 | May 21st, 2007 09:49 AM |
