| View Poll Results: Which of these cylinder heads? | |||
| AFR 185 |
0 | 0% |
| AFR 205 |
5 | 45.45% |
| Procomp |
0 | 0% |
| Canfield 195 |
6 | 54.55% |
| Kiethcraft 195 |
0 | 0% |
| Kiethcraft 210 |
0 | 0% |
| Voters: 11. You may not vote on this poll | |||
FFR Cobra and 05' GT vert
What cylinder heads do you like?
On a 408w running 10.5:1 compression with a 60cc chamber carburated, which heads do you like of these only? No trickflows becasue I need to retain stockish exhaust port height. This motor is for my FFR cobra kit car
AFR 205 AFR 185 canfield 195 Procomp 210 KiethCraft 195 Kiethcraft 210
Go big or go home! |
Atomized
where's the tfs 205's? lol Thats where my vote is
spray and pray |
We have made great power with the Vic Jr's
Just a truck 5.4 3v: 264hp 317ft lbs rock stock piecing together the next project faster than your first sexual experience |
#4 | |
How about RHS (racing head solutions) There pretty good heads for the price
to many parts and money to be so slow
1989 GT
KB 2.1L Flowzilla
Really, AFR 185's are raised too? Somehow i thought that they are stock height. Isn't only high ports and R with raised exhaust, all other TFS stock height?
The heads I have are the 206cc R heads which are raised
.750. If im correct he AFR is only raised .125 which will work fine and the canfield is raised .400 which is a push but could finagle the header to work.
I don't know if the 185s are raised, but they have no business being on a 408. Most of the heads on the market have raised or altered exhaust ports. Its not a big deal at all.
The R heads are raised .500. High Ports are raised .750. Canfields are raised .400. AFR 205s are raised .125 and the 225s are raised .375. All of which are really insignificant if you think about it. If worst comes to worst, build a set of headers or have a custom set made.
The issue is if they are raised too must the side pipes will not line up correctly. Levy racing will make a customer header with the side pipes for the trick flow r heads but he want $4000 for the complete set of headers and side pipes. There is enough adjustment to perfectly line up up to a .400 raised port. What do you think of the afr 205?
#11 | |
They are hand made custom and yes they are totally ceramic coated.
1990 LX hatch
I've had good luck with my procomps... Even tho they are from the bottom shelf at Big Lots.
1989 Mustang Gt
Run me and find out!!!
t.e.a. high ports on a 408...
lol
weeee foooord!
Ya....What did the car run on motor?
PeteAndersonRacing.com |
1990 LX hatch
low 12's,(never could cut good 60's) best mph was a hair under 116, with 3.55's
2008 Mustang GT
11.35@123
AFR has to sets of 185s. the 185s are stock height and 185 comp heads are .125 raised on the exh just like the 205s! I have them on my car, great head! kinda like my wife lmao!!!
CRT-Performance Tuned by Jeff Chambers in Norwalk Ohio, 2.6 Kenne Bell, 62mm T-Body, LT Headers, O/R H-pipe, 4.10s, Foxlake CNC Heads, VSR Stage 2 cams 530/447 Mustang Dyno www.crt-performance.com |
not bad at all for some heads that cheap....obviously it could have gone faster with some better hooking up considering the trap speed...
1991 mustang 5.0
Threads Similar to: What cylinder heads do you like?
| cylinder heads | mustangboy8909 | 5.0 Mustangs | 2 | March 16th, 2009 10:11 PM |
| cylinder heads | Blk01ponyGT | 99-04 | 2 | October 7th, 2007 09:40 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 10:55 PM |
| Cylinder Heads | thewayshemoves | 99-04 | 7 | December 26th, 2006 08:35 PM |
