351 w Heads
Has anyone on this forum ever used a set of 351 w on a fuel injected 302? I might be picking up a set for a good price just wondering if its a good performance choice? Anything i should look out for?
Thanks Joe
302, EdelBrock Upper and Lower Intake, GT40 Aluminum Heads, E303, Shaved&Balanced Crank w/bearings, BBK Induction, SuperChip, BBK Shortys, BBK Off Road HPipe, Flow Masters, 4:10, 2" Eibach Drop Springs, 17x9 Chrome Cobra R, 245/45ZR17 |
equivalent to a gt40 head
so you can literally just swap the 351w heads onto a 302?? what is involved in the prcoess??
My friends used to wonder Why i joined the air force. Now they wonder why they didn't. |
I think 351W has 1/2" head bolts, 302 has 7/16. Other than that, it's a straight bolt on (no pun intended).
wow and how does it affect the performance?
#6 | |
Billy Weston
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
like what 15 hp??? im excited to do this!!!
Stock for stock 69 and 70 351W heads flow about 30 more cfm on the intake than an E7. Exhaust flow is about the same. 69 and 70 351W heads use 1.84/1.54 valves and most of the other 351W heads run 1.78/1.46 valves and have larger chambers. Anything other than the 69 and 70 heads is pretty much a wash and not worth the time.
#9 | |
#10 | ||
Billy Weston
Most aftermarket heads come drilled 1/2"
#11 | |
+1 You can use head bushings too.
#12 | |||
Threads Similar to: 351 w Heads
| GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s | BillR1970 | Parts | 8 | May 12th, 2009 10:01 PM |
| GT40 heads vs GTP heads | 99TurboV6Stang | 5.0 Mustangs | 9 | September 18th, 2007 10:34 PM |
| RHS heads , are they good cylinder heads? | hitorx | 5.0 Mustangs | 25 | May 12th, 2007 10:55 PM |
| 289 Heads | ezra27 | General Tech | 0 | December 31st, 2006 12:09 AM |
| Boss 302 Heads Same As Cleveland Heads? | ken5_0 | Classic Mustangs | 8 | September 25th, 2006 04:18 PM |
