92 LX 5.0 future mods?
Old May 4th, 2009, 06:26 PM   #1
skboost is on a distinguished road
I just got my 92 LX the other day and I am trying to decide what I want to do next with it.
The person I bought the car from was planning on putting a supercharger on it but never got around to it I guess. However, The fuel modifications were done to the car, so right now there is alot of fuel for a stock engine.
The mods done to the car are:
headers
x-pipe
flows with dumps
pro 5.0 shifter
urethane tranny mount
egr spacer
24lb injectors
BBK adjustable fuel regulator
255lph pump
Tuned ECU
I am looking for any input on what to do next, I plan on eventually installing a single turbo kit. But for right now, should I install the stock injectors and fuel pump, or what upgrades could I go with to make this extra fuel useful for now.
Any information is appreciated.
Old May 4th, 2009, 06:29 PM   #2
91 LX
13.7@101
what kind of tuning is done to the ECU? the injectors are fine. look into buying new cylinder heads, a camshaft, and an intake. you already have enough fuel for that
Old May 4th, 2009, 06:32 PM   #3
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
Suspension, gears, tires, heads, cam, & intake.
Old May 4th, 2009, 06:36 PM   #4
I really don't know what kind of tuning was done to the ESU, the seller of the car just told me it was tuned for the fuel mods. I just didn't understand why the car was tuned for that extra fuel, when it's not needed.
Old May 4th, 2009, 06:40 PM   #5
Holy Dick Castle!
dr.gonzo!'s Avatar
5.0 Mustang Tech Q & A
This is a pretty good read. Some people will argue about the technical stuff but its still a good place to start.
Old May 4th, 2009, 06:46 PM   #6
Thanks, I will check it out for sure.
Old May 5th, 2009, 12:07 PM   #7
I am looking at a cam, intake, and heads.... I am doing some research, but could anyone direct me to some products that could be used well with a turbo setup, as well as naturally aspirated?
Old May 5th, 2009, 01:53 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Do heads before anything.
Old May 5th, 2009, 02:25 PM   #9
88_FiveOh's Avatar
1988 lx
13.13@101.78
88_FiveOh is on a distinguished road
do heads and then a cam to match. checkout trick flow. They sell a top end kit that's all designed to run perfectly together.
302 out of a lincoln lsc, Cobra upper and lower, 1.6 rr's, msd cap, bbk equal lengths, off road h pipe, mac pro chambers, 4:10's, bbk drag launch springs, 4cylinder tranny, short shifter, 20% tint, and 6k H.I.D's. 13.13@101mph 1.8 60ft on D/R's
Old May 5th, 2009, 05:44 PM   #10
jat
jat is on a distinguished road
Send a message via AIM to jat
which kit?
Old May 5th, 2009, 05:47 PM   #11
91 LX
13.7@101
track heat
Old May 5th, 2009, 05:52 PM   #12
jat
ill take a look thank you
Old May 5th, 2009, 10:14 PM   #13
cool thanks, I heard alot of good things about trick flow.
Old May 13th, 2009, 10:10 AM   #14
That track heat kit is great, I plan on buying that in the future when I have some more money for mods. In the meantime, should I go with some stock injectors for my car because it is a stock setup? The MAF is original and I am getting way too much fuel the way it is now.
The only thing I am also wondering is, if the computer was actually tuned for these injectors, would sock ones make it run poorly. From doing searching, most people are saying all you need is a MAF calibrated for the 24lb injectors.
Old May 13th, 2009, 10:20 AM   #15
95StangMX's Avatar
95 Mustang GT
how does the car run.....if it runs good then I would say leave it alone for now and get heads......doesnt seem like enough fuel for a charger though...
Old May 13th, 2009, 11:33 AM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
How do you figure you are getting too much fuel?
Old May 13th, 2009, 01:26 PM   #17
baine21225's Avatar
you should have a matching maf, i'd look into a set of heads and gears first
Old May 14th, 2009, 11:30 AM   #18
because of the size of the injectors with a stock motor. Also, it smells like its running very rich; although, it doesn't have cats,just an x pipe then dumps. I'll take a look at the plugs when I get a chance.
The car runs good. I just wasn't sure If I should be running these injectors or not. If I wont gain anything from switching back to stock, I'll keep them in.
Thanks for the input guys.
Old May 14th, 2009, 12:05 PM   #19
91 LX
13.7@101
no you wont gain anything by switching back to factory 19lb/hr injectors, as long as you have a matching MAF for your 24's. If you havent driven a car without cats the smell of the exhaust might lead you to believe it is running rich.
Old May 14th, 2009, 01:21 PM   #20
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The injectors aren't too big. The 5 liter Cobras had 24lb injectors and they were only 15hp more than the base model Mustang. Its not getting too much fuel. It might be running rich if the computer wasn't calibrated for the bigger injectors though. I wonder if someone did a Cobra computer conversion on this car.
Threads Similar to: 92 LX 5.0 future mods?
The Car of the Future Notcho The Clubhouse 5 March 20th, 2009 01:16 PM
Future value of our Stangs garydahl 2005 - 2010 22 June 25th, 2008 08:02 PM
"Future Mods" In The Sig RAGEman The Clubhouse 99 April 4th, 2008 07:51 PM
My future mods. energiesource 99-04 15 April 10th, 2007 02:22 AM
Future Mods List for the Terminator Chris02 99-04 20 November 6th, 2006 01:31 PM
