8.8 R&r...
Old May 5th, 2009, 12:12 AM   #1
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
8.8 R&r...
Hey guys, just thought I'd share this with you. Started today after work and finished up just a few minutes ago. I'll post pictures of the new rear-end and install once I get it back from Strange.
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old May 6th, 2009, 12:33 AM   #2
1988 GT
I didn't see the sense in making a new thread so I'll just add updates here until the car is up and running...
The passenger seat is going in once I get it out of my D.D. The harnesses will go in the same time as the other seat.
Old May 6th, 2009, 01:02 AM   #3
Nice 5.0's Avatar
1993
12.9 @ 105
Nice 5.0 is on a distinguished road
What are the plans for the rear.
Old May 6th, 2009, 10:02 AM   #4
jack90gt's Avatar
1988 Mustang gt
Lookin for 11's this summer
jack90gt is on a distinguished road
Racecar.......LOL
Just a 302, How fast can it be????
Old May 6th, 2009, 03:13 PM   #5
1988 GT
33-spline axels, 4.10 gear, spool, c-clip eliminator kit, welded tubes to center section, and whatever bearings/seals that go along with it.
Originally Posted by jack90gt View Post
Racecar.......LOL
You know it!
Old May 6th, 2009, 11:17 PM   #6
89Domindart's Avatar
89mustanglx5.0
89Domindart is on a distinguished road
Send a message via AIM to 89Domindart
Id like to see your diff cover to see if it looks like mine. the 8.8s are slightly different from 7.5s I guess, acording to LRS - Mustang 7.5 & 8.8 Rear Axle info - LRS Blog
http://i31.photobucket.com/albums/c390/Domindart/My%20Mustang/DSC00039-1.jpg
89 5.0 for sale! in the classifieds section
Old May 7th, 2009, 01:15 AM   #7
1998 Cobra
13.24@105.66
indeed.
weeee foooord!
Old May 7th, 2009, 10:25 AM   #8
1988 GT
I'll take some pictures and post them up when I get home from work.
Old May 7th, 2009, 05:40 PM   #9
1988 Mustang Notch
it's a bad bitch..i promise
CAMN89GT is infamous around these parts
How much did Strange charge you? When is this beast gonna be ready ?
P.S are you putting a big tire on this car? You know your rims/tire was hitting the pipe see pic #4 , if you want to prevent this, lmk i just did mine to put my 26x10.5 on.. I bent the tail pipe right where u were hitting when i ran tails.
'88 Notch ~ T-70 & Faceplated GForce!
Tuned by [B][I][U]Kurgan Motorsports[/U][/I][/B]
Old May 7th, 2009, 08:56 PM   #10
1988 GT
Here's my diff. cover...
Old May 7th, 2009, 08:59 PM   #11
1988 GT
$1400, as soon as I get the rear-end back and this god-damn fuel issue figured out!
Yeah I'm planning on running a 26x8.5x15... I noticed that too, I'll have to figure something out. If you're local I'll pm you when I get the rear-end back and we'll figure something out.
Old May 11th, 2009, 11:37 AM   #12
1988 GT
So, with the rear-end out I would like to upgrade my controll arms from the GRIPP ones, to something like UPR adjustables.... I am currently in the possition to only purchase either Upper's or Lower's. The question being, what would I benefit from more or do they only work best when both are installed(upper/lower)? Also, when adjusted what are they controlling?
IE: if my car hooks but pulls to the right would I adjust the controll arms to straighten the car out after the launch?
Are they for how the car squats when launching?
~ Thank you
Old May 11th, 2009, 06:26 PM   #13
1988 GT
BUMP.... for input?
Old May 11th, 2009, 07:46 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
~ Thank you
Get some double adjustable uppers. Get the Team Z Motorsports upper kit.
An anti roll bar will adjust the car going left or right. You can make adjustments with the upper arms too but I like to install them with zero preload and use an anti roll device to keep the car straight.
Squating is bad.
If you want to fix that tire rub problem just rotate the tail pipes a bit in the mufflers. No need to put dents in the tail pipes.
Old May 12th, 2009, 11:09 AM   #15
1988 GT
Squating is bad.
I was begining to wonder if no liked me, lmao. Ok so rear uppers are the way to go until I get the perches for the coilovers welded on. With this anti-roll bar, is that something that bolts in or welds in? Would you also recommend a Team Z anti-roll bar? and are they also double adjustable? Also are the spherical buschings worth the money? Thanks for you input I appreciate it.
Old May 12th, 2009, 04:02 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The anti roll device welds in.
Here are the uppers:
Mustang Mini-tub kits, street and race front and rear supension components - Team Z Motorsports
Old June 11th, 2009, 05:17 PM   #17
1988 GT
I'll be picking up my rear end tomorrow and I just was wondering if anyone has experience with UPR adjustable controll arms? Will a spherical bearing work with the stock style controll arm? Also has anyone installed those battle box reinforcements? I'm wondering if their a bolt in or weld in project? Thanks and I'll be posting pictures after I pick it up...
Old June 11th, 2009, 07:40 PM   #18
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
pretty sure theres some welding to be done with the battle boxes.....thats the torque box reinforcement stuff right
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old June 12th, 2009, 12:09 AM   #19
1988 GT
Yeah, well hopefully I can get my hands on a welder before next weekend...
Old June 12th, 2009, 12:22 AM   #20
1990 Mustang GT
will you try to take some pics as you go and post em with some notes....im still not exactly sure how to go about this process...
1990 GT
2004 Impala SS
2001 Tacoma
Threads Similar to: 8.8 R&r...
CAR Audio/Video=Pics,Ideas,& Info/SQ & SPL Post your Systems+ Pros&Cons Just Another Stang Audio/Video 22 April 6th, 2010 02:03 PM
Motha$$^%*&^&W%^goddamff%^(*&&^&(!!!!!! OcOnnor220 99-04 31 June 18th, 2009 06:50 PM
Is There a big Diference between K&N Cold Air and Plain K&N Filter? wiesman2613 99-04 17 March 19th, 2009 07:41 PM
