1989 Mustang GT 5.0
decision to make...
should i save lots of money and just turbo my stock motor and make around 400hp (running low boost to be safe) or just hit my stock motor with 100 shot of nitrous and wait and build my motor for a turbo setup...
B&G makes a turbo kit under $3000 MM max grip package $4500 (for suspension and chassis) build the rear end $1000
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" Last edited by EscortSportage; May 5th, 2009 at 08:32 AM. |
#2 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
Do you still have stock h/c/i?
1989 Mustang GT 5.0
yes,
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
#4 | |
Holy Dick Castle!
I would start off with a top end kit first, then worry about boost, it would be cheaper than a turbo then if you do add boost it will kick even more ass. And if I did a turbo kit on an old stock engine I would replace the head gaskets so the heads have to come off anyways, why use the e7's again?
![]() Last edited by dr.gonzo!; May 5th, 2009 at 09:19 AM. |
1989 Mustang GT 5.0
my motor has like 2000 miles on it...and money is the issue right now, and i dont need crazy amount of power just yet, chassis and suspension/braking is more important... plus 5psi of boost (give or take) on a gutted FOX = its gonna MOVE
#6 | |
Holy Dick Castle!
Then I guess you could go either way. the trickflow kit is about $2500 and sell the stage 1 cam that comes with it and go for the stage 2 cam or you can go with this kit Paxton Automotive Corp. 1001831 - Paxton NOVI-1000 Mustang Supercharger Kitsfor $2300.
I would go with the n/a top end kit first but thats just me or you could have some fun with nitrous and good set of tires for now until your budget is good. Nitrous is the best bang for the buck but after so long with the money being put into refill it you could have bought a s/c kit
![]() Last edited by dr.gonzo!; May 5th, 2009 at 09:47 AM. |
1989 Mustang GT 5.0
well, u put a turbo stang vs an NA stang and tell me how pulls better, in my opinon boost runs the street or track...unless ur pushing big cubes. ( 302 is small) umm and i dont want to run a supercharger...
supercharger's are actually easier to work/tune, plus a smaller pulley is cheaper than having to buy a boost controller for when you want to get that more hp.
Dart Iron Eagle block & Pro 1 heads DSS 347 80lb injectors D1-SC blueovalindustries headers BBK o/r X Flowmaster cat-back 3.73 gears |
#9 | |
Holy Dick Castle!
I found this on The Turbo Forums.com
94 Cobra Turbo Tech Street Kit 60-1 hifi stock engine @ 5 psi of boost 12.65 @ 108 330/405 this is 5psi on gt-40 heads and intake. if you cant run 12.65 on the trick flow kit something is wrong lol
1989 Mustang GT 5.0
turbochargers are the most efficient power adders on the planet...and i want to run turbo, hands down
#11 | |
Holy Dick Castle!
Then do it. E7's are the most restrictive
1989 Mustang GT 5.0
im planning on it, and thats why im getting feedback from u guys...b4 i do it
1989 Mustang GT 5.0
eventually ill build an engine from ground up, bt for now just beat around town with a stocker engine, and lil bit of boost.....romping on people, then when we pull over and they are like damn what are u running......"i dont know bro, its a stock motor"
i say hit it with the sauce, but hey thats me, cheaper, gets you the same results, more money to put towards building the motor you want
#15 | ||
Your heads are the weakest link any way you slice it. But if you are planning for this car to be a turbo car in the end anyway, you might as well get the turbo kit now. Sounds like your decision is already made. If you want to run a turbo, then run a turbo.
ebay has the best deals!
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
#17 | |
1990 LX hatch
+1 A good kit will be able to take the stock engine to the breaking point with only fuel, and tuning mods.
nice avatar
piece of advice if u cant afford a 3000 dollar kit and scared of breaking the stock block.. dont buy the turbo kit.. plain and simple.
if its just a track car fine go ahead just be prepared to have to shell out more money for a motor. |
i say turbo it and put an f cam in there with the stock motor. here is an example of what that exact combo will do
Threads Similar to: decision to make...
| Have to make a decision | JASonic | The Clubhouse | 5 | June 24th, 2008 10:49 PM |
| decision to make | mantis3567 | 99-04 | 1 | January 29th, 2008 10:52 PM |
| So now I have a decision to make... | VaporS197 | 2005 - 2010 | 5 | January 3rd, 2008 01:11 PM |
| Need to make a decision... | FireHawk | V6 Mustangs | 19 | September 30th, 2007 03:17 PM |
| Help me make my decision | BigTimInNokeCity | 96-98 | 3 | December 21st, 2006 06:04 PM |
