1987 Mustang GT 5.0 5spd
Bad Bearing in steering wheel/ tilt assembly?
I have alot of play in my tilt on my steering wheel, is there a bearing i can change in tilt assembly?
1987 Mustang GT 5.0 5spd t-roofs, FRPP 4.10 gears, MM subframe connectors, FRPP a arms, Tokico Hp struts/shocks, alum rad, electric fan, dcc fan control unit, 6g alternator |
SVTfocus, F250
i doubt its a bearing. mine had alot of play but the mounts for the steering column came loose. take the cover off of the column and tighten the bolts and see if it gets better
+1
+2
+3 good call, fixed
Threads Similar to: Bad Bearing in steering wheel/ tilt assembly?
| bad wheel bearing | syccmayde | 96-98 | 4 | April 24th, 2010 03:59 PM |
| HUB Assembly or Wheel Bearing Replacement? | Antfo89 | Modular Mustangs | 1 | April 18th, 2009 12:52 PM |
| Tilt Steering Wheel Loose | InFlames | 2005 - 2010 | 4 | November 26th, 2008 03:44 AM |
| need a tilt wheel? | SALIV8 | 5.0 Mustangs | 9 | May 15th, 2008 04:15 PM |
| How To Remove The Hub / Wheel Bearing Assembly | 2000v6 | V6 Mustangs | 0 | September 17th, 2006 10:41 PM |
