Intake Gaskets suck...
i just put an explorer intake on about 2 months ago and now the stupid rubber seal on the front of the lower intake starts to leak....
is there an easier fix for this? if i have to pull the upper and lower intake off, does anyone have suggestions on how to prevent this from happening again?
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
i wud at least try to silicone it or something first
#3 | |
2006 Mustang v6
quit being lazy and just replace it with a new gasket. They arn't hard to replace.
Former :06 4.0L 6spd Mustang...TR6060 Now: 06 Mustang 4.6L 3V with some mods ![]() MAD Crew 23
No bucks, no Buck Rogers
Possibly get a better quality gasket from your Ford dealer instead of a cheap Auto Zone imitation.
I replaced a few original 1989 seals on my car with 230k miles... the diff pinion seal and the T-5 tranny output shaft seal. I used Auto Zone seals.. I figured hell they had them in stock and they were only a few bucks each. I installed them and drove the car down the road, about 1 mile. Oil was already running out of them. I was PISSED. But, I decided to bite the bullet.. went to my local FORD dealer, ordered the seals for about $20 EACH, and put them in. NO leaks at all. Its been about 30k miles since then, and still no leaks. If you buy cheap parts to fix something, you will end up having to REdo it, and buy the quality stuff anyway. My motto is: "Buying cheap merchandise to save money is like stopping a clock to save time."
'87 2.3 Notch with +4 cylinder mod ![]() MM's Resident Aggie Black Stang Crew Member #11 |
1994 GT
did u use the one that came on the intake? cause that would be y its leakin..use some rtv on the front and back of the lower intake...thats how it is on my car and works great for me
Cohagan Engineering, Inc. |
#6 | |
fel pro gasket and a gracious dab in the corners of the valley seal
weeee foooord!
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
This was no cheap gasket...
I purchased the fel-pro head set. Fel-pro is good stuff. it was the rubber ones not cork. its just such a pain to seat them right... its a lot of work to do that lower set again. I'm gonna RTV the hell out of it and see what happens. worst case scenario i buy a new set and use tons of RTV next time... thanks guys
1988 GT
Just to clearify... is the RTV instead of the gasket(no gasket at all)? Also I've heard that it's best to let the RTV sit for a few minutes and get "tacky", is this an old wives tale? Or just simply not true.
1982 GT t-top
no proof of purchase
theres no need to use those rubber gaskets just use a nice thick bead o black rtv and your good
Don't use the front and rear seal pieces that come with intake gaskets. Even if they are some type of rubber they are prone to leaking. Ditch those pieces and uses some sort of RTV, I prefer Permatex "Right Stuff"
89 LX Coupe: Factory 5.0, common performance and suspension bolt-ons (306 build inprogress) 86 GT: (current 1/4 project) will have primarily Team Z suspension and chassis additions, 408 with nitrous in the works
#13 | |
![]() The stuff that squirts out is not doing you any good (maybe short term it is) and if too much squirts out, it will break away and be floating around in your oil/coolant. Think of RTV and gaskets like leveling materail used on cerarmic tile floors or putty/body filler on a body part. It is only there to smooth out the imperfections between two layers, not provide support or for a buildup.
#14 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
I used the rubber ones with a thick bead of rtv under the rubber, no problems.
#15 | |
Correct, no end gasket. RTV with the end gaskets will cause them to squeeze out and/or leak most of the time. I never let the RTV get tacky. I want it to firmly attach to the bottom of the intake so it doesn't leak.
rtv for the win
1988 mustang GT
13.06@106.09
+2 rtv no gasket
88 mustang 5.0 e7 heads edelbrock intake mezeire electric water pump... electric fan... f cam 4.10 gears t-5 tranny best pass 13.06 @ 106.09 |
#19 | |
1988 GT
Proud American
peramtex great stuff. FTW
Threads Similar to: Intake Gaskets suck...
| re-using intake manifold gaskets | 01 blue bullitt | 99-04 | 8 | November 19th, 2008 02:56 PM |
| Replacing intake manifold gaskets... | SteviGX | 96-98 | 4 | May 28th, 2008 09:34 PM |
| gaskets | mmvi | V6 Mustangs | 7 | April 27th, 2007 02:27 PM |
| Gaskets | Tony_90fox | 5.0 Mustangs | 5 | March 29th, 2007 12:03 AM |
