351c and 351w?
Old May 7th, 2009, 11:39 AM   #1
1988 mustang ssp
seanmouth is on a distinguished road
351c and 351w?
what are the differences between the 351 clevelend and the 351 windsor?
i have a 351 windsor in the garage not sure if it is the 2v or 4v havent checked yet.
Old May 7th, 2009, 11:42 AM   #2
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
The 351C is a 4 bolt main I think and is stronger and better for racing and high hp, but the downside is the after market is not very big, as far as I know. And Im betting its a 2V
Old May 7th, 2009, 11:48 AM   #3
92_5.SLOW is on a distinguished road
^x2 the cleveland is a beast but there isn't very many parts
America is all about speed, hot nasty bad ass speed
Old May 7th, 2009, 12:04 PM   #4
Proud American
MustangMatt96GT's Avatar
early 351w blocks are stinger than laters. 351w can hold slot more power than a 302 block
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old May 7th, 2009, 12:12 PM   #5
haywood11's Avatar
1988 mustang lx
interior torn out!
haywood11 is on a distinguished road
Send a message via Yahoo to haywood11
2v clevalands are garbage. they suck dog balls when its hott outside. if you go with a 351c go with the 4v. my father in law has one and it rips good. and to answer your question about the difference, pretty much everything on the clevlands are different from the windsors.
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD.
Plans: full black interior, black paint and supercharger???
Old May 7th, 2009, 03:17 PM   #6
86er's Avatar
best thing is use the best of both, W block and C heads. Makes a killer motor.
make sure its not a 351M it looks the same as the cleveland it just has a 1.1 inch taller deck height.
Just a truck
Old May 7th, 2009, 04:23 PM   #7
1988 Mustang
88Saleen is on a distinguished road
Send a message via AIM to 88Saleen
so whats up with the 351M. whats different about them? just the deck height?
Old May 7th, 2009, 04:50 PM   #8
1998 Cobra
13.24@105.66
only cobra jet clevelands were 4 bolt, there are plenty of 2 bolt cleveland blocks out there
so that's why edelbrock makes aftermarket 2v style heads? and everyone runs the closed chamber 2v aussie heads
Modified series engines suck, best thing to do to a 351m is find a 400 crank
weeee foooord!
Old May 7th, 2009, 05:55 PM   #9
86er's Avatar
Heads have like a 82cc chamber small ports, just not a great motor for performance
best thing to do with them is a rv cam, 0deck the block with some flat tops and watch it pull stumps all day long
Just a truck
Old May 7th, 2009, 07:41 PM   #10
1985 Mustang GT
viperlocc is on a distinguished road
mind sound like a dumb question, but ive been seeing it everywhere...
2v and 4v? explain...
Old May 7th, 2009, 09:40 PM   #11
Holy Dick Castle!
dr.gonzo!'s Avatar
V for valves per cylinder
Old May 7th, 2009, 09:47 PM   #12
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
2v and 4v has to do with the port size on these earlier engines not valve per cylinders. the 2v is larger combustion chamber and the 4v is a smaller combustion chamber. nothing to do with how many valves per cylinder on these
Old May 7th, 2009, 09:52 PM   #13
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
my dad has a cleveland in his drag car stroked to a 400 with blue thunder heads and some other goods and runs low 8s n/a. So clevelands are not garbage by any means
Old May 7th, 2009, 11:22 PM   #14
ryans88gt's Avatar
v stands for venturi as in the number of venturis the carbs had that went with the corresponding heads. 4v heads went with the 4 barrel carbs. 2v heads went with the 2 barrel carbs.
nobody really builds clevelands anymore because parts are scarce and good blocks are hard to come by. If you find 5 blocks, one or two of them might be good to make more than 400 hp if you sonic check them.
Old May 8th, 2009, 06:36 AM   #15
haywood11's Avatar
1988 mustang lx
interior torn out!
by saying "garbage" what i meant is what ryans88gt said.
Old May 8th, 2009, 06:38 AM   #16
haywood11's Avatar
1988 mustang lx
interior torn out!
my bad if i came off looking like a douche, sorry
Old May 8th, 2009, 09:01 AM   #17
Holy Dick Castle!
dr.gonzo!'s Avatar
oops. I just looked it up ad found 4 valve 351 heads and thought thats what it ment.
Thats probably why I was betting it was a 2v lol they need to stop printing "32V northstar" on the side of shit
Old May 8th, 2009, 10:18 AM   #18
chriswao's Avatar
1989 mustang gt
8th 5.70
chriswao is on a distinguished road
I have had three 600rwhp 351 clev's there the best thing since sliced bread in my book but people have different out looks on them. I run 4v closed chamberd chi heads from alstralia on mine... makes awsome numbers. I've ran both 2v and 4v both can be a good set up if you use the right parts. but you def need a 4 bolt main block to do so. and like they said there hard to come by the motor in my car now...I found the block in cali it was being used as an air compressor!!
Originally Posted by Dennis View Post
great thanks i think i just lost 50 points off of my IQ reading that
Old May 8th, 2009, 11:29 AM   #19
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
They are hard to come but yes but it all depends on your plans with it. It your serious about building one you can always get an aftermarket one. The one we have now is a dart block
Threads Similar to: 351c and 351w?
351c stang87 5.0 Mustangs 4 May 2nd, 2009 10:50 PM
351C 2V or 4V? aha1989 Classic Mustangs 2 April 12th, 2009 10:06 PM
351c pettydvm Classic Mustangs 45 February 15th, 2008 10:54 AM
351C rjhurtu 5.0 Mustangs 1 April 9th, 2007 09:12 AM
351c in a 96 v6 possible? 94v6blkndred V6 Mustangs 1 April 8th, 2007 11:43 PM
