Solenoid wiring help
LinkBack (3) Thread Tools
Old May 7th, 2009, 01:26 PM   3 links from elsewhere to this Post. Click to view. #1
1989 Mustang LX 5.0
sniperd is on a distinguished road
Unhappy
Hi All,
I have a 89 Mustang 5.0. I was installing a new positive battery terminal last night and broke a post on my old solenoid, I went out and got a new one (Luckily this one is metal so hopefully its not crap like the previous one). And im having nothing but problems re-assembling it.
Whenever I hookup the wires in the order as i previously (thought) that they were hooked up in, the car turns over and sparks bad, including melting the metal in which the positive terminal hooks up too.
Can someone point out what i have wrong here?
When i connect the wire from the starter the car will do the above...
Thanks in advance for any help with this.
Old May 7th, 2009, 03:47 PM   #2
1992 Lx
11.39@119.24
big wire coming from the starter on 1 side, EVERYTHING else on the other side
Old May 7th, 2009, 03:56 PM   #3
88-gt-t-top's Avatar
1988 GT
88-gt-t-top is on a distinguished road
Make sure that nothing on the battery side isn't grounding out... I.E. hitting something on the fender, anything to create a ground.
Originally Posted by 1slo5.0 View Post
You never save anything when you buy cheap off brand junk.
Originally Posted by e3sean View Post
its like taking a pill for a headach but the side affect is dihrrea, runny nose, blood clots, and aids.......well at least the headach is gone right......
Old May 7th, 2009, 04:22 PM   #4
1989 Mustang LX 5.0
Exclamation
Isnt that how i have it setup in the picture?
Old May 7th, 2009, 04:22 PM   #5
1989 Mustang LX 5.0
Will do
Old May 7th, 2009, 04:27 PM   #6
1992 Lx
11.39@119.24
dam i dont have my fox anymore to go look at it, does you starter have 2 wires coming from it or 1?
Old May 7th, 2009, 04:48 PM   #7
1989 Mustang LX 5.0
It appears to possibly have 2, but one goes into a black casing and runs towards the back of the engine, possibly looping back around through the harness and coming out as one of those other wires.
But only 1 obvious (big) wire... I should probably just pony up for a volt tester and try and figure it out off a wiring diagram but im hoping to not have to go their.
Old May 7th, 2009, 04:53 PM   #8
1998 Cobra
13.24@105.66
your diagram looks right.
sparks are caused by arcing..
so when you hit the starter solenoid to turn it on, something hot is touching ground!
Have you checked your starter cable to make sure it hasn't burned on the header? That could possibly be what destroyed your old solenoid to begin with
weeee foooord!
Old May 7th, 2009, 04:58 PM   #9
baine21225's Avatar
your dead to me, over
Old May 7th, 2009, 05:03 PM   #10
1992 Lx
11.39@119.24
baby the machs just so much nicer.... 4v ftw right?....
Old May 7th, 2009, 05:06 PM   #11
baine21225's Avatar
...........maybe
Old May 7th, 2009, 06:42 PM   #12
1989 Mustang LX 5.0
I'll check for grounding when I get home tonight, Thanks for all the help guys.
p.s. My old solenoid was destroyed by me overtightening the shit plastic stock one
Old May 7th, 2009, 06:43 PM   #13
89LX347's Avatar
89LX347 will become famous soon enough
no, goin from a 5.0 (or any 2v motor for that matter) to a mod motor is like learnin to ride a bike again. i didnt wan to even touch my brothers cobra besides taking off the charger and pullin the tranny. havin to mess with all those timing chains and all that. stuffed in that little space. spark plug changes in the 2v mod motors i feel like i have to charge money when my friends want me to change them cause you have to take off the cold air and the fuel injector harnesses and the spark plug wire boots come off and you have to set them just right in there. mkaes me mad just talkin about it. put some turbos on the cobras and they will move out but that take alot more $$ than i wanna spend. sorry for the rant, i just dont agree
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old May 7th, 2009, 07:08 PM   #14
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Yeah dude, those mod motors are a mess. Nice, but a mess lol
Old May 7th, 2009, 07:09 PM   #15
baine21225's Avatar
pretty much anything new is a PITA to work on
Old May 7th, 2009, 07:25 PM   #16
Chris951's Avatar
1991 mustang 5.0
which is why 5.0's are ftw
Old May 7th, 2009, 07:51 PM   #17
1988 GT
LMFAO.... My bro had a 04 conv. I will never own one of those cars, atleast until I'm older, more experienced, and more patient.
Old May 7th, 2009, 08:24 PM   #18
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
What he is describing is not a grounding out issue. He has power at the wrong spot at the wrong time. It sparks and arcs because of the amperage the starter is drawing. He is hooking the starter up to a hot pole which is causing the starter to turn over. Its wired wrong but without knowing where all the wires are going from the picture, its going to be hard to fix over the internet.
Old May 15th, 2009, 04:51 PM   #19
1989 Mustang LX 5.0
FYI for anyone that has this problem in the future. Im fairly certain the solenoid was bad, as i replaced it and it fixed the issue. Although it could be because i 'ungrounded' something while replacing the wires.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/122489-solenoid-wiring-help.html
5.0 Mustang Solenoid Wiring This thread Refback October 23rd, 2010 12:33 PM
93 Mustang Solenoid Wiring - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback June 22nd, 2010 03:21 PM
Mustang Starter Solenoid Wiring - Overview : Kosmix This thread Refback October 29th, 2009 11:47 AM
Threads Similar to: Solenoid wiring help
solenoid problem? 69fastback Classic Mustangs 20 August 29th, 2008 11:55 AM
NX solenoid brackets? 95wip General Tech 5 June 22nd, 2008 02:37 AM
solenoid 1BADSTANG 5.0 Mustangs 6 January 26th, 2008 02:56 PM
How can u tell if its the starter or the solenoid? noyz25 5.0 Mustangs 11 October 28th, 2007 09:48 AM
solenoid after solenoid after solennoid fakesaleen General Tech 13 May 11th, 2007 09:42 PM
