WOT A/C Cutoff Relay
What could be if any the results of taking out this relay if I have no A/C?
Does this switch affect any part of the tps. Reason I am Asking. Built the car and finished a few months ago. Had a chip made on the computer from the car that donated everything except the body. Only changes I made were Long Tubes, and routed all engine bay wires behind the dash. Now the car is bucking at low rpm's and at some times will backfire under light loads, usually after it has just been cranked up. |
I dont see what it would hurt to leave it. It doesnt affect the throttle it affects the A/C clutch and since you dont have A/C, its already not doing anything. If it were something necessary, Im sure you would be able to find some type of eliminator or something for it.
I have already taken the wiring out of the car thats why I asked. If you think it is something that should at least be left in I am going to replace the wiring and plug it back in.
If worst comes to worst I am just going to make a trip to the dyno after I put my Nitrous kit on and have them hook it up to the computer to see what is wrong. Just get them to redo the chip unless it is something that I have to fix. Was just wondering if it was anything someone might think I did and could fix without having to make the trip to the dyno, and or pay them to find out what it is. |
Bucking? Are you 100% sure the timing and plug wires are right? That uasually the cause of backfires and bucking.
Threads Similar to: WOT A/C Cutoff Relay
| fueld pump cutoff as security | catchtheroadrunner | 2005 - 2010 | 0 | September 26th, 2007 03:46 PM |
| Relay | akatagyourit | 2.3 Mustangs | 2 | July 21st, 2007 12:39 PM |
| fuel relay | Mustang RacR94 | V6 Mustangs | 3 | April 15th, 2007 05:24 PM |
| Exhaust Cutoff? | rene9 | 96-98 | 3 | October 7th, 2006 02:04 PM |
| Moroso Battery Disconnect Switch (External Cutoff) - Wiring | 99mustang232 | General Tech | 4 | September 23rd, 2006 05:59 PM |
