351w swap
Old May 7th, 2009, 04:36 PM   #1
Lazor05 is on a distinguished road
351w swap
I'm looking at doing a 351 swap into my 82 GT. What years would be the best for me to look for for the 351? I found an 86 out of a bronco for $400 without the carb and intake. I know I have to replace the oil pan, headers probably mounts etc. But I also found a roller block for $450 with the stock pistons crank and other parts. I was just wondering if someone could give me some advice on what block to use, I haven't had any luck finding info. thanks
Old May 7th, 2009, 04:46 PM   #2
1998 Cobra
13.24@105.66
Ideally the older the block, the stronger, but that's not always true.
Try to stay away from smogger blocks unless you plan on rebuilding them..
I would go with the newer roller motor
weeee foooord!
Old May 7th, 2009, 05:57 PM   #3
86er's Avatar
ideal is 69-74, they have the thickest main webbings. You can buy comps roller conversion piece for like 50 bucks or set of retro lifters for 500 bucks.
Dont buy a roller block just because its a roller, plenty of ways around that.
Man i keep seeing people paying all this money for them, I have like 6 I paid 68 dollars for at the local pull a part
Just a truck
Old May 7th, 2009, 09:39 PM   #4
1993 mustang hatch back
sctravis77 is on a distinguished road
Send a message via AIM to sctravis77
You can use the dual sump oil pan and pick up from a older crown vic instead of buying $150 ford racing one. I put mine in this week and fit awesome.
Old May 7th, 2009, 10:41 PM   #5
Iwannagofast's Avatar
1990 Mustang GT
havent gone since gears
Iwannagofast will become famous soon enough
Send a message via MSN to Iwannagofast
ok this conversion your tlkin about is the spider piece right....can any block be converted with just using that piece
1990 GT
Pro 5.0, 3.73s, TFS Intake, Flows
2004 Impala SS
Supercharged(stock), DD
2001 Tacoma
2.5" Lift, K&N cai, TB Spacer, Magnaflow, Elec. Fan, Stereo MODS!!
Originally Posted by JBIGBOOTSY View Post
my table spoon engine is bigger than the tea spoon engine!
Old May 8th, 2009, 12:01 AM   #6
Dang maybe I should be patient and keep looking then. Thanks for the advice so far guys. I'm trying to do a budget build for this. Its just going to be a DD that will see the track a few times but not much. I know with the 302 gt40's are a popular budget head but would these be too restrictive for a 351? and what intake would you recommend, and cam. haha could you maybe just give me a few ideas of builds. This will be my first build. I would like to keep the power down low. Also is the 351 a really torque motor? And in case your wondering im talking about the 351w, guess I never specified
Old May 11th, 2009, 01:36 PM   #7
1990 Mustang GT
im bumping this to get an answer to my question above
1990 GT
2004 Impala SS
2001 Tacoma
Old May 11th, 2009, 01:55 PM   #8
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
gt40ps are to restrictive for a 302, let alonea 351.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old May 11th, 2009, 02:16 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It depends on what your goals are. More than likely any 351W block will work. If you want to use a hydraulic roller cam and the factory style roller lifters than get the roller block.
Old May 11th, 2009, 02:17 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Doing a "roller conversion" on a non roller block is stupid. Do it right and get the link bar lifters.
Old May 11th, 2009, 02:23 PM   #11
1990 Mustang GT
o ok....so any 351w can be made roller by using the retro fit lifters....ill probly do solid roller when i build my 408....unless thats not a good idea.....
i have just heard so many different answers to questions about converting to roller and haveing to use a special cam or bot being able to go roller if it wasnt a roller to begin with....im just need one good straight answer
1990 GT
2004 Impala SS
2001 Tacoma
Old May 11th, 2009, 03:33 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
There is nothing to convert. People have been running roller cams long before the factory started putting them engines. The problem is when you try to use factory roller lifters in a non roller block. People think you can just throw any old cam in a non factory roller block with factory roller lifters. You can't, you have to use a small base circle cam or the lifters will be pushed to high in the lifter bores which will affect oiling to the lifters and the top end of the engine. In addition to that, small base circle cams are junk. They are weaker, flex more, transmit more harmonics, stability issues, etc. People like to save money and spend $100 and use some junk used factory roller lifters, spider and dog bones on a non roller block instead of spending $400 on a set of link bar hydraulic roller lifters. I can't see why someone would spend a ton of money on an engine and then pinch pennies on the camshaft and valvetrain which is will make or break your power figures. A shit valve train is going to severely limit your rpm and horsepower potential. The solution to this problem is to run whatever cam you want and hydraulic link bar roller lifters which have been around since they started slicing bread. Another option is to run a solid roller cam.....which is the best option.
Old May 11th, 2009, 05:28 PM   #13
1990 Mustang GT
thank you for finally straightening that out for me....that really explains a lot....yes thats what im gonna do is get the link bar lifters then....no u were saying to use hydraulic roller lifter but then you said that solid is the best....what is the difference between the two...wat are some pros and cons of each and does it affect drive ability because mine will be more of a street strip car
1990 GT
2004 Impala SS
2001 Tacoma
Old May 11th, 2009, 06:35 PM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Hydraulic you can just throw in and never touch again. They are hydraulicly adjusted so to speak with engine oil. Limited camshaft profiles.
Solid requires some maintenance from time to time in the form of adjusting valves. Not nearly as often as people will try to make you think. The people that say you have to "adjust valve lash all the time" have never owned a solid cam. Camshaft profiles can be more radial with a solid lifter and rpm and horsepower potential is greater as well. Valvetrain stability is better with a solid cam.
Old May 11th, 2009, 06:42 PM   #15
laztug's Avatar
1993 Mustang GT
laztug is on a distinguished road
How good are stock prorted 351w heads?
Stock 5.0 Motor M/T Drag Radials
E.T.- 13.859
MPH-97.23
60 foot-1.853
Old May 11th, 2009, 06:47 PM   #16
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Not worth a damn. Most likely won't flow for shit because anybody that is good at porting won't waste the time on a set of stock 351W heads.
Threads Similar to: 351w swap
351w swap into 00 v6 got poney V6 Mustangs 13 March 15th, 2011 04:58 PM
351w Swap shadowgames81 5.0 Mustangs 3 March 23rd, 2009 06:43 PM
351w swap guys, need your help! built351w 5.0 Mustangs 11 June 17th, 2008 02:19 PM
'93 LX Notchback needs a 351W swap Velvet Leopard 2.3 Mustangs 1 December 29th, 2006 03:15 PM
1993 2.3L to 351W swap Velvet Leopard 5.0 Mustangs 0 December 19th, 2006 05:07 PM
