Car is backfiring
Old May 7th, 2009, 07:28 PM   #1
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Car is backfiring
So ever since I got my car it will backfire through the exhaust. It only does it on WOT runs when I'm shifting around 5k. Otherwise it won't do it if I keep the rpms down. But the past couple months now it has been backfiring through the intake when its cold. It will only do it once in a while though like once a week and when it happens it will only do it once maybe twice. I know I need to set my timing but could I be running lean or rich? I can't really tell myself because I have an o/r h-pipe and dumps so it always smells. I was thinking about getting an adjustible fpr. Would that help along with setting my timing?
Old May 7th, 2009, 10:14 PM   #2
mxnate116's Avatar
SVTfocus, F250
mxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the roughmxnate116 is a jewel in the rough
depends on what your fuel pressure is now. if its high or low an adjustable could help, but so could a new stock one.
i put a new fpr on mine and it ran amazing for two weeks then slowly went back to shit(popping through the intake all the time). i need to check my fuel pressure again to see if it crapped out again.
Old May 7th, 2009, 10:20 PM   #3
Holy Dick Castle!
dr.gonzo!'s Avatar
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
dr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant futuredr.gonzo! has a brilliant future
How long has it been since you had a tune up? Any exhaust leaks or loose header bolts?
Old May 7th, 2009, 11:38 PM   #4
1987 Mustang GT 5.0 5spd
Ntv69 is on a distinguished road
Subscribing here, i have same problem with my 87. You still runnin speed density system? Mine also backfires around 5k also when about to shift. I too have a off road x pipe, and have to real smelly exhaust and fuel smell. I bought plugs,rotor,cap,wires,k&n filter cleaner. Gonna tune up, sdjust timing, change oil, flush rad clean up my dirty k&n. Im hoping if i put on a short belt and eliminate the smog pump it will help with the exhaust smell.
1987 Mustang GT 5.0 5spd t-roofs, FRPP 4.10 gears, MM subframe connectors, FRPP a arms, Tokico Hp struts/shocks, alum rad, electric fan, dcc fan control unit, 6g alternator
Old May 7th, 2009, 11:54 PM   #5
Chris951's Avatar
1991 mustang 5.0
Actually yeah, Both the bolts came out at one point on the #4 cylinder and I think the bolt holes in the head are warped because I cannot get new ones in.
And I did a tune up when I bought it in september. New plugs, cap and rotor, cleaned the TB and iac, etc. I've also seafoamed it like 3 times lol.
Old May 7th, 2009, 11:56 PM   #6
1991 Mustang LX 5.0
14.001@99
Jackson is on a distinguished road
My car did the same thing after I installed my O/R H pipe until I removed my smog pump. Im not exactly sure why it made a difference (I have a few theories but Im not a mechanic so i can only guess) but as soon as i yanked the pump, put on a short belt and capped the smog stuff it quit backfiring...
Originally Posted by JBIGBOOTSY View Post
Ditch the Brakes, they will only slow you down more.
Old May 7th, 2009, 11:57 PM   #7
Chris951's Avatar
1991 mustang 5.0
Yeah I'm still on SD. Sounds like we have a similar problem because mine backfires right in the middle of shifts at 5k.
Old May 7th, 2009, 11:58 PM   #8
Chris951's Avatar
1991 mustang 5.0
I'm currently running a short belt. My smog pump seized a few months ago.
Old May 8th, 2009, 12:39 AM   #9
PolishSasquatch is on a distinguished road
im getting backfriing over 4000 rpm. but im running an 85 carbed motor, with no exhaust on it ( open pipe after the car, its only temporary untill i can afford mufflers). Could it be a lean out backfire?
Old May 8th, 2009, 12:43 AM   #10
What size belt? power steering? i assume no ac with the t-roofs
Old May 8th, 2009, 12:56 AM   #11
Chris951's Avatar
1991 mustang 5.0
83.5" belt. I have power steering and ac but the ac will be gone soon because it doesn't work
Old May 8th, 2009, 01:44 AM   #12
hmmmmmmm......
PeteAndersonRacing.com
Old May 8th, 2009, 10:57 AM   #13
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
When my car pops through the intake it's due to lean conditions. Often low fuel pressure. It did it more often in the winter now. If you have an adjustable fpr make sure that once it's adjusted, that the nut is tight.
I had m y car tuned on 40psi or so. When back for a slight retune and it was going leaner and leaner. Turned out my fpr nut was loose and it was slowly dropping over the course of a month.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old May 8th, 2009, 03:32 PM   #14
hopper is on a distinguished road
yes ther are AC on t-tops,
Also i had the same prob with the back fireing although it was a carbed engine.
this would only happen under load at 5K.
found out there was a very very very small crack in the boot of one of the plug wires, onced changes no problems any longer
Old May 8th, 2009, 06:05 PM   #15
Chris951's Avatar
1991 mustang 5.0
I'm gonna get an adjustable fpr when i can get some money.
Old May 8th, 2009, 07:50 PM   #16
Does a kirban adj regulator attach right too stock fuel rails? Anyone runni a pressure gauge beside it??
Old May 8th, 2009, 11:14 PM   #17
1993 5.ohhhh
12.97 @140mph
kirban bolts right in on the rail. I put my guage on the rail were the shrader vavle went. I just put a nos fitting in.
Threads Similar to: Car is backfiring
Backfiring ...again Somebody Help! blakehunter316 5.0 Mustangs 1 April 6th, 2008 11:47 PM
Intake Backfiring 90mustang 5.0 Mustangs 10 November 12th, 2007 10:17 PM
My Stang is backfiring! WombRaider 5.0 Mustangs 10 October 30th, 2007 09:15 PM
Backfiring 00vabchgt General Tech 6 June 19th, 2007 08:56 PM
Backfiring 00vabchgt 99-04 0 May 24th, 2007 04:26 PM
