Trick Flow Intake Problems... - Page 2
Old May 8th, 2009, 12:08 PM   #21
baine21225's Avatar
i don't know, i can't figure it out
Old May 8th, 2009, 01:25 PM   #22
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by 1989Gt. View Post
wait a whilstle noise ok wheni put my cai on my car i had a new whistle is that normal maybe not tightened right? why is that i thought it was normal but i felt like it wasnt normal its a loud whilstle
Do you have a stock throttle body?
What kind of cai kit is it? Try taking the air filter off and driving it once and see if it changes. Also make sure it is installed correctly and the clamps are tight.
Old May 8th, 2009, 01:26 PM   #23
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by martinez23 View Post
can u explain the carb cleaner ?? do u mean run the engine and srpay carb cleaner near or on the throttle body and listen if the engine revs?? also i hear a wistle when i drive when i accelerate but i dont notice a power lose so where should i look ?
Thanks
Do you have a stock throttle body or an aftermarket throttle body.
Old May 8th, 2009, 05:09 PM   #24
1989Gt.'s Avatar
1989 Mustang GT
1989Gt. is on a distinguished road
Send a message via AIM to 1989Gt. Send a message via Skype™ to 1989Gt.
its a mac and i did take the filter off and it still does it.... and im pretty sure all the clamps are fine the throttle body is stock yes....
Old May 10th, 2009, 02:29 PM   #25
Foxracer1606's Avatar
Foxracer1606 is on a distinguished road
so now my car keeps cuttin out and dying when i come to a stop...can anyone help
Old May 10th, 2009, 04:06 PM   #26
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Did you phase the rotor when you put the distributor back in? The distributor has to point to #1 on the cap when you install it. That is what triggers the injectors. Did you set the timing correctly by removing the spout and then plugging the spout back in after you set the timing?
Old May 13th, 2009, 02:30 AM   #27
what do u mean phase the rotor....and its cuttin out just every once in awhile when im driving..
Old May 13th, 2009, 06:37 AM   #28
haywood11's Avatar
1988 mustang lx
interior torn out!
haywood11 is on a distinguished road
Send a message via Yahoo to haywood11
not to sound stupid but do you think the mass air meter is not calibrated right?
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD.
Plans: full black interior, black paint and supercharger???
Old May 13th, 2009, 08:28 AM   #29
92twotone's Avatar
1992
12.0
92twotone is on a distinguished road
dont want to mixmatatch forums or anything...but i was reading this on the corral the other day, its got a lot of good info in it about people with the similar feeling of loss of power after installing the tfs kit. i personally have never used and tfs products so this is not coming from me...just something i stubled across and felt it wsa relevant. good luck with the whistle and cutting out by the way.
Trickflow H/C/I low power? - Corral Forums
92gt,dark emerald green metallic/titanium silver two tone. canfields, jay allen custom grind cam, edelbrock super vic, power elbow and a buncha other crap
89 lx 5.0 hatch BONE stock
Old May 13th, 2009, 08:40 AM   #30
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
When you install the distributor, the rotor must point to number one on the cap. That is what fires the injectors. If the distributor is not installed with the rotor pointing in the proper location, the engine will run but will be down on power and may have some driveability issues.
Old May 13th, 2009, 08:44 AM   #31
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
These people have all screwed something up. The first post in that thread is a bad driver. I can tell that from just reading the post. There are other issues from using Ford Racing plug wires to having not enough timing in the car. I'd be willing to bet that none of them installed the distributor properly either.
Old May 13th, 2009, 08:50 AM   #32
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Furthermore, the TFS top end kit will give you 11 second horsepower if you have a good suspension, slicks and an 11 second driver (the most important part).
Old May 13th, 2009, 09:43 AM   #33
baine21225's Avatar
is there something wrong with ford racing wires?
Old May 13th, 2009, 09:59 AM   #34
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I have yet to see a set that didn't arc all over the place. I've fixed alot of driveability problems for people that were caused by a brand new set of Ford Racing wires. I bought a Mustang last year that had a surging idle. I took the Ford Racing wires off and put a set of used MSD wires on that I had laying around. Surging idle fixed. Another car I fixed had a miss fire at cruising speeds. Brand new Ford Racing wires. I replaced the wires with some used stock replacement wires that I had laying around, problem solved.
Old May 13th, 2009, 01:12 PM   #35
baine21225's Avatar
interesting
Old May 13th, 2009, 04:20 PM   #36
I had the street heat top end kit on a previous mustang and I was very happy with it.. I've used tfs stuff on many cars and never had a quality control issue with there shit unlike allot of other more expensive pos companys out there.
I would say the hci package is a good buy but don't throw that shit on a car with stock exhaust, maf, injectors and fuel pump and think you'll get 400hp to the wheel. You have to do the supporting mods, get a tune and you'll be happy. Most people f up the install, don't adjust the valve lash correct etc
I'd purchase the kit again
Old May 13th, 2009, 06:11 PM   #37
1986 mustang gt
1fst5.0 is on a distinguished road
i had ford racing wires, they lit up like christmas trees at nite. also, the whislting has to do with the idle air bypass holes not being smooth or having flash on them.
Old May 13th, 2009, 09:05 PM   #38
1993lxnotch's Avatar
1993 Mustang lx coupe
1993lxnotch is on a distinguished road
well im running ford racing wires looks like new wires is another part to add to the list....the list is like a honey do list....never stops growing.
Old May 13th, 2009, 09:41 PM   #39
baine21225's Avatar
get used to it broski
Old May 14th, 2009, 07:55 AM   #40
92twotone's Avatar
1992
12.0
i personally have never used any tfs products...i have heard some horror stories from a few guys, but i suspect due to ignorance of installer. i just posted that link to the corral to show that there are other people feeling the way hes feeling, so that everyone could help figure out a way for him to get more power out of his hci package...and i agree that people put a little to much confidence in the tfs hci package...they think that it makes them have a 10 sec drag car instantly, but like people have said before a fast car is a system of parts that compliment each other to make the power. guess that corral thread is junk, my bad guys haha.
Threads Similar to: Trick Flow Intake Problems...
Trick Flow intake Squints 5.0 Mustangs 23 March 26th, 2009 07:07 PM
Trick Flow Intake MustangMatt96GT Modular Mustangs 16 May 13th, 2007 05:10 PM
Trick FLow intake test! MustangMatt96GT Modular Mustangs 2 April 12th, 2007 08:20 PM
trick flow intake Fastpitchdad 5.0 Mustangs 6 December 9th, 2006 02:08 AM
