Trick Flow Intake Problems...
I just put the upper and lower Trick Flow streetburner intake on my 92 mustang along with 24lb injectors, MAF sensor calibrated to the injectors, 255 fuel pump and a 70mm throttle body and EGR plate...and my problem is that there is a whistling at idle and it almost seems like i lost power. so do i need a tune or what?
sounds like a vacuum leak
get some carb cleaner and spray her down |
spray what...and would that cause it to loose power?
welcome to the whistling throttle bodys club. its normal. the loss of power is probably all in your head
a vacuum leak could cause you to loose power....using the carb cleaner to spray around different areas where there could possibly be a leak lets you know when you find it because the engine will rev a lil
well the loss of power is def not in my head..ive had this car for like 6 years now so i know what it had before...do i need a special tune or anything for these bolt ons
No you don't need a special tune. The whistling is either a vacuum leak or the throttle body. The throttle body whistle is harmless. Vacuum leaks can cost you power. Do the carb cleaner trick mentioned above. Make sure everything is hooked up correctly. Are the fuel injectors plugged in to the proper wires? Did you have the distributor out?
Yea all the injectors are hooked up right..and also had the distributor out..
maybe a timing issue then
aight...so what do i look for on the balancer when i put the timing light on it
Did you phase the rotor when you put the distributor back in? The distributor has to point to #1 on the cap when you install it. That is what triggers the injectors.
wait a whilstle noise ok wheni put my cai on my car i had a new whistle is that normal maybe not tightened right? why is that i thought it was normal but i felt like it wasnt normal its a loud whilstle
2001 Mustang GT
can u explain the carb cleaner ?? do u mean run the engine and srpay carb cleaner near or on the throttle body and listen if the engine revs?? also i hear a wistle when i drive when i accelerate but i dont notice a power lose so where should i look ?
Thanks |
1982 GT t-top
no proof of purchase
^ with the engine running spray carb cleaner on anything that could possibly be leaking if the engine revs up you've found a vac leak, altho aftermarket cai,filter, throttle body, etc will whistle it's normal
1982 GT t-top
interesting.... guess imma dummy, i like the carb cleaner idea, sweet
88 5.0 with bbk shorties, bassani x-pipe w/o cats, custom 2.5in w/flowmasters. t-5 conversion, gt40p heads cobra upper and lower. stock SD. Plans: full black interior, black paint and supercharger??? |
1993 5.ohhhh
12.97 @140mph
Spray were the lower intake manifold meets the block, were the upper meets the lower manifold. Between the upper and the heads. By the tb were it meets the upper. All of these can cause a vacuum leak.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed ![]() --Moates Quarter horse $225-- --Cobra intake $150-- --tremec 3550 bell and shifter $1100--
My brother in laws setup is the same as yours - he bought a Professional Products TB when we did his TFS setup, and it whistles all day long...
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
my car whistles too?
"Whip out your dick you'll either get it sucked or get smacked..." "That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1982 GT t-top
^ I wonder why
Threads Similar to: Trick Flow Intake Problems...
| Trick Flow intake | Squints | 5.0 Mustangs | 23 | March 26th, 2009 08:07 PM |
| Trick Flow Intake | MustangMatt96GT | Modular Mustangs | 16 | May 13th, 2007 06:10 PM |
| Trick FLow intake test! | MustangMatt96GT | Modular Mustangs | 2 | April 12th, 2007 09:20 PM |
| trick flow intake | Fastpitchdad | 5.0 Mustangs | 6 | December 9th, 2006 03:08 AM |
