88 LX 5.0 Convertable
Sea Foam Question
Ok! I know this will sound stupid to some of you but I really dont know. WHERE do you put the stuff in at? Pictures or a diagram would be a big help!
Robbie_________________ 88 LX Convertible 5.0 84 GT - Project 66 F100 |
Priest of the Car Gods
Pick a vaccuum line - brake booster works well. Basically anything that you can disconnect and have enough slack so that you're not pouring the sea foam into the line, but slipping the line into the can and letting it suck the sea foam up. DON'T put all the way in the sea foam, though! It should always be "slurping" it.
in oil.....in fuel....or pull a vacuum line like off the brake booster and slowly put some into it with the car running
If you put it in the oil, change your oil in a few days or less.
And for what it's worth, Lucas is a much better fuel additive.
1991 mustang 5.0
Yeah I run lucas in the fuel and oil. I use the Brake booster line. Once I used the S line which goes directly into the manifold.
Got it! Thanks guys. I'll use the brake booster line.
1988 GT
What is this Sea Foam you people speak of?
it is supposed to clean out carbon build up in the engine
"That's how Dad did it, that's how America does it... and it's worked out pretty well so far..." |
1989 mustang gt
8th 5.70
sea foam is really good stuff... it cleans every thing pretty much! what ajax cant get off sea foam can!! lol
Threads Similar to: Sea Foam Question
| sea foam question. | ByPopularDemand | V6 Mustangs | 17 | April 9th, 2009 11:06 PM |
| sea foam ??????? | armymike63b | 99-04 | 13 | August 17th, 2008 01:03 PM |
| Sea Foam | Corey | 5.0 Mustangs | 5 | April 17th, 2008 02:32 AM |
| how to sea foam ?? | 96gtponyred | 96-98 | 5 | July 22nd, 2007 12:53 PM |
| Help after using sea foam... | 04GTAMPA | 99-04 | 4 | June 7th, 2007 10:16 PM |
