1990 f150 5.0l Swapped to a Fox
Old January 23rd, 2007, 05:42 PM   #1
dStoltenberg is on a distinguished road
Hello all. I recently picked up my first fox-body mustang, 1985 t-tops hatch, no motor, transmission, or rear end. A friend has a 5.0l 302 out of a 1990 f150 that he is willing to sell me for a good price. motor only has 15k miles on it. Will this motor fit like a stock 5.0? if not what is needed for the conversion?
Old January 23rd, 2007, 06:31 PM   #2
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
yeh, but get a different manifold... you'll need a tranny as wel and a rear end obviouslyl...
Old January 23rd, 2007, 07:02 PM   #3
G-Man's Avatar
G-Man is on a distinguished road
Ya you will need to convert a few things like the daul sump oil pan, the headers might need to be replaced because the angle of the exhaust on mustangs is differenet, basicly the headers might not fit. I cant be shure about the transmission though
Old January 23rd, 2007, 08:03 PM   #4
i dont reccomend putting an f150 tranny in a mustang...=/
you will need new headers most definately. the ones you have might fit, but they wont bolt to any mustang mid-pipes. On top of that your oil pan and picup will need to be replaced. Intake manifold, replace that with a mustang manifold. Depends on wether or not the engine is EFI or Carb. A 1990 should be efi. You can get all the exhuast components used for about $500-$600, unless you get aftermarket pieces. The rear end should be about $600 or $700 if you buy it used. That f150 should have one.. You'll need a tranny, that should be about $2K, a driveshaft ($500).
I'll assume it'll cost about $3-5K to put that motor in that fox considering you dont have anything but a motor and a shell. Your missing some key components, such as a tranny, and a rear end. And then im not even sure if you have any kind of suspension on that car or not. Sounds like a big project. Unless you buy everything used which personally, some things i wouldnt, you're looking at spending some serious cash. It might be cheaper to buy a used mustang.
Old January 23rd, 2007, 10:13 PM   #5
Already got an 8.8" with 3.55's for a rear, just have to go pick it up. The Engine is EFI, but headers and oil pan are no big deal. I have a donor car in the works for the transmission and suspension components (along with the newer style front end conversion), but thats not official yet.
Old January 24th, 2007, 06:26 AM   #6
FastBack71 is on a distinguished road
looks like ur good to go then, good luck
My friends used to wonder Why i joined the air force. Now they wonder why they didn't.
Old January 24th, 2007, 05:42 PM   #7
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I thought that the truck 302 and the Mustang 302 were different?
It's my understanding that the trucks use bank fuel injection versus the mustangs sequential, the firing order is different, the pistons aren't forged, you don't get roller everything, etc, etc.
Basically, I thought the truck block was the non H.O. motor?
O o
/¯/______________________
\_\
Old January 24th, 2007, 07:55 PM   #8
94cobraclone's Avatar
94cobraclone is on a distinguished road
I had a 92 f150 the 302 is a roller engine with bank firing on the injectors. I converted mine over to mas air flow.
Powerdyne supercharger
Ebrock perf upper/lower intake
Steeda 18 cam
GT-40 heads
MSD Ignition
All forged bottom end
BBK headers
3:73 rear end
T-5 Manual Trans
Old January 24th, 2007, 08:19 PM   #9
Mass Air conversion is a pretty easy mod IMO. And if you have the motor and the rear i'd say do the swap providing you have the cash to get a tranny and the car's body has suspension.
Old January 27th, 2007, 08:48 AM   #10
Suspensions all there, granted its not bolted to the car, but it is there. Going to start pulling the motor out of the truck after work today. transmision should be easy to find, mustang parts are cheap as hell around here. So i'll need to convert to mass airflow as well as go to a dual sump oil pan & pickup, new headers, and intake manifold? Shouldn't be two bad.
I like the truck 94cobraclone, i love stepside pickups. A friend of mine has a '54.
Old January 28th, 2007, 12:56 AM   #11
86er's Avatar
where do you find your prices? used parts shouldnt be anywhere near that, rear end 300 tops, exhaust headers 200 tops for stock style headers, intake manifold, people give away stock ones here, a t5 can be had for the cheap and what kind of driveshaft is 500 an aluminum one is 250.
You suck at shopping
Just a truck
Old January 28th, 2007, 08:41 PM   #12
vfast will become famous soon enough
you can use the truck lower intake a big plus over a stock 5.0 one..the upper will have to be swapped out for an edelbrock upper
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old January 28th, 2007, 08:58 PM   #13
Can always rebuild the t5 out of the donor car, only thing is i don't know what the gearing is. I'll more than likely go with a stock intake for awhile, trick flow in the future. Just want to get it on the street for now.
Old January 28th, 2007, 10:58 PM   #14
5-0stank is on a distinguished road
was that ur truck 94cobraclone???
1995 GT::Sold!
Looking for another stang...
Threads Similar to: 1990 f150 5.0l Swapped to a Fox
PI Swapped vs. 99-04 RandoGT 96-98 23 October 1st, 2007 07:40 PM
Can oil pump shaft be swapped from the top?? noyz25 5.0 Mustangs 2 July 28th, 2007 11:30 PM
Swapped my New Engine! oasr87 V6 Mustangs 21 July 24th, 2007 12:43 PM
PI Swapped Motor 98vortech Modular Mustangs 7 September 19th, 2006 05:24 PM
swapped but won't start 97Stang 96-98 11 February 26th, 2006 06:32 PM
