old gas?
Old May 8th, 2009, 07:57 PM   #1
mikegilbert810 is on a distinguished road
Question
old gas?
Car was stored 2 winters ago and only fired up about 3 times since, don't ask me why but I never put stabilizer in but I put it in today and some octane boost. Car had a full tank (premium gas) when stored and fires up first crack every time although it smells a little funky. Will I kill my car or sjouke the stabilizer and better octane get me through this tank fine?
Old May 8th, 2009, 10:24 PM   #2
1986 mustang gt
1fst5.0 is on a distinguished road
might have to change ur plugs after wards, but i would drop the tank
Old May 8th, 2009, 10:33 PM   #3
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
drain the tank dump in some seafoam and some fresh gas
Old May 9th, 2009, 05:47 PM   #4
1998 Cobra
13.24@105.66
or just drive it real easy, and refill with premium. Does it have a wood grain varnish smell?
weeee foooord!
Old May 9th, 2009, 05:55 PM   #5
BlessedHellride's Avatar
1988 Notchback
11.19 @ 122mph N/A
BlessedHellride will become famous soon enough
Two year old gas can do more damage than people think. It can cause valves to start to stick open as the varnish breaks loose and travels through the fuel system. Amongst other known problems. Drain the tank and flush the system.
Old May 9th, 2009, 07:13 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
How much gas is in the tank? Just fill it up with some good gas and drive it.
Old May 9th, 2009, 07:15 PM   #7
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Show me a valve that sticks open and I'll show you a broken valve spring. Valves don't stick unless there is a mechanical failure.
Old May 9th, 2009, 07:22 PM   #8
1988 Notchback
11.19 @ 122mph N/A
My Father just had to go through stuck valves in a head because of bad gas on a Toyota pick up truck. I know it can happen. It can clog your injectors also. The valve sticks open due to the varnish getting into the valve guides. Some worse than others. There was nothing wrong with the valve springs either.
Old May 9th, 2009, 07:35 PM   #9
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That is one of the most foolish things I've ever heard. If a valve sticks open and the valve is still in one piece and the spring and retainer is still attached then the spring has to be so worn out that it will not function properly anymore (mechanical failure). Familiarize yourself with a valve train and you will understand why this simply doesn't happen unless there is a mechanical failure.
Old May 9th, 2009, 07:42 PM   #10
1988 Notchback
11.19 @ 122mph N/A
Familiarize myself with how a valve train works? Before you under mind me, let me tell you that I am a second generation engine builder. My Father is near 60 and has been doing it since was 15. Under his supervision, I built my first engine at the age of 13, an opposed 4 cylinder Volkswagon 1600cc engine, now I am 33y/o. I'm not trying to brag about my nor my Fathers knowledge, but trust me, we can hold our own when it comes to engine building and how the valve train is affected by tarnished fuel. Maybe it is you that needs to do some research. I hope for goodness sakes your not one of these super internet forum engine builders.
Old May 9th, 2009, 07:50 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Well good for you. Apearently valvetrain is something you need to study more.
No I'm not a "super internet forum engine builder", I have a bit of experience....
Old May 9th, 2009, 08:11 PM   #12
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
I would agree with this.
And I would trust Darrell's judgement over most people on this forum.
Old May 9th, 2009, 08:35 PM   #13
1sl0w88's Avatar
88 LX 5.0 Convertable
1sl0w88 is on a distinguished road
Whoa dude! Maybe YOU need to do some research before you make that statement.
Robbie
_________________
88 LX Convertible 5.0
84 GT - Project
66 F100
Old May 9th, 2009, 09:25 PM   #14
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
That's weird but I have a 1964 cadillac coupe de ville that I started and drove with 4 year old gas two years ago and I have had no problems. But I'm not an engine builder either. I've only built handful of motors so i'm not up to your standards. I can build some beasts online thought. wana e race bro?
spray and pray
Threads Similar to: old gas?
With gas prices this way ive decided to get a gas saver...Should I trade the stang? Drick The Clubhouse 18 September 2nd, 2010 03:26 PM
Gas Smoothgrandmama The Clubhouse 31 October 17th, 2008 05:00 PM
2007 Pump Gas Drags 32 of the fastest pump gas cars Mellon Videos 7 June 14th, 2008 12:08 PM
gas charlesnash 2005 - 2010 5 March 18th, 2007 10:28 AM
I have gas OTreborO 5.0 Mustangs 1 August 25th, 2006 02:25 PM
