Head gasket. - Page 2
LinkBack (1) Thread Tools
Old May 11th, 2009, 08:52 PM   #21
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
I have p's but I torqued them to arp's specs.
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old May 11th, 2009, 09:46 PM   #22
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by JBIGBOOTSY View Post
THere is 4 lbft diffrence between the two. Split the diffrence? Also will the special 1/2 inch to 7/16" trickflow washers, replace the arp head stud washers, or should I put the Arp washers on top of the trickflow ones?
I doubt there will be a torque difference in the washers. Use what is on the head.
Old May 12th, 2009, 10:55 AM   #23
ryans88gt's Avatar
put washers on top of the 7/16" to 1/2" bushings.
9333pt1 is an awesome gasket and is a MLS core gasket, with laminate on the outside and the fire-rings are Siamesed so that the fire rings are much less likely to push out.
Best part is, the gaskets are cheap....you can buy them on summit.
Follow the head bolt torque sequence. After you fire it up and warm it up to operating temperature and let it cool completely back down overnight, retorque the head bolts one at a time by loosening them 1/4 turn and retorqing them.
For Arp studs I use 95 ft lbs top and 85 ft lbs bottom. For bolts I use 85 ft lbs top and 80 bottom.
Retorquing the bolts makes a big difference in the clamping force as most of them will go another 1/16 to 1/4 turn after a hot/cool cycle.
Old May 12th, 2009, 10:59 AM   #24
ryans88gt's Avatar
oh yeah and I put permatex non-hardening sealant on all the bolt threads
and quality moly lube on the head and washers or nut and washers depending on if you are using studs or bolts.
Old May 12th, 2009, 12:45 PM   #25
flamestang's Avatar
flamestang is on a distinguished road
I've ran the Fell pro 1011 w/arp studs on 10 psi and made about 30 passes and had no problems there also good insurance.
Old May 12th, 2009, 06:21 PM   #26
JBIGBOOTSY's Avatar
1990 LX hatch
Got it done. It makes boost alot sooner now.
Ryans88gt, is the re torque a must? I have never done that before. I went with the 1011-2's . I did use the molly lube and torqued to spec.
Old May 12th, 2009, 07:51 PM   #27
89LX347's Avatar
89LX347 will become famous soon enough
its not a must, a lot of people dont do it and dont have any problems, but it is certainly recommended
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old May 12th, 2009, 07:58 PM   #28
JBIGBOOTSY's Avatar
1990 LX hatch
too late now, but the rockers are 0 lash + a 1/4 turn right?
Old May 12th, 2009, 08:00 PM   #29
89LX347's Avatar
yes sir
Old May 13th, 2009, 02:25 PM   #30
ryans88gt's Avatar
If you want the gasket to live long in a boosted 302 block, a retorque is highly recommended.
It is never too late to retorque them, unless you already blew them out again.
Old May 14th, 2009, 02:40 AM   #31
JBIGBOOTSY's Avatar
1990 LX hatch
imonit!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/122833-head-gasket.html
Are Felpro 9333pt1 Pre-flattened This thread Refback November 5th, 2010 03:13 PM
Threads Similar to: Head gasket.
Head gasket gone!! ssprofession 96-98 7 February 2nd, 2009 02:03 AM
intake manifold gasket or head gasket? rasalibre 5.0 Mustangs 5 November 26th, 2008 05:37 PM
Head gasket izze01 5.0 Mustangs 8 November 15th, 2008 07:23 PM
Head gasket? Elder 4V / SVT 14 June 22nd, 2008 12:33 AM
head gasket popmyclutch V6 Mustangs 14 September 12th, 2007 10:48 PM
